Fenix LR40R seems the latest product, no link just a picture?
This is definitely better than the regular Sofirn 26650 batteries. A bit less than the Sofirn 21700. So there is still a little more performance to be gained if anyone wants to use a top high drain cell.
Will you be labeling these new batteries as a Sofirn brand or as the original brand and model?
Can you say what model they are?
Sofirn pls make the SS bezel
We already talked about it. They might make it seperately later on, but the current light will have black anodized aluminum bezel to keep costs down.
1. SP70 will be a single emitter flashlight. How about:
SPX17? (the X could mark, that it is a more complex flashlight, and the 17 would mark, that it is 17 thousand lumens at maximum)
or
SPX144/SPX18 (similar, but marking emitters distribution, not thousand lumens)
2. I would suggest it this way:
one XHP35 HI for throw, let’s say it is about 2000 lumens with 200000 candela alone - 5000K 80 CRI (maybe reflector diameter is around 6.5 cm, SMO)
eight further emitters as below (alternating around a circle):
four XHP50.2 for comfortable flooding: let’s say it is about 1750×4 = 7000 lumens - 4500K 90 CRI (reflector diameter is around 3.5 cm, stronger OP texture)
four XHP35 HI for slightly more concentrated (intermediate) beam: 2000×4 = 8000 lumens - 5000K 80 CRI (reflector diameter is around 3.5 cm, SMO)
—> 17 000 lumens total, maybe user should activate these all simultaneously, or one by one (e.g. only flood or only throw, or flood + intermediate or throw + intermediate) - with at least one dedicated button
3. I would suggest 2 battery compartment serially connected as this: a single compartment could be of 3× 21700 batteries parallel, this will give not too thick battery tube, but a great possibility to support high current cells of 20-30 ampers and above (Vapcell / Shockli 4500mAh 20A /LS21700SF/ or Samsung INR21700-40T 30A - resulting a 13500mAh 8.4V battery pack capable of 60A continuous (max ~ 360W) or around 11000mAh 8.4V battery pack capable of 90A continuous (max ~540W) - also, Sofirn 21700 4000mAh ~15-20A could be good as well)
Actual flashlight power could be around 200-240W, but we need to over-design the battery pack to let the users have less battery strain, while using this flashlight.
Me too, this is why I suggest the above
7000 lumens is a good effort! I wonder what the throw numbers are? We can probably hit the 1km mark by slicing the dome?
Throw numbers are posted above. About 710 meters or 125Kcd.
Slicing the dome will definitely increase throw.
Is there anyway that Sofirn would sell the light with the sliced led? Thnx
I doubt it. It was talked about in the GT70 tread & concluded that manufactures might not want or be able to do this correctly.
Don’t take that as an answer from Sofirn though. It is only my thoughts on the subject.
Thanks for the answer Teacher, there would be a great push if Sofirn could do that…. Even if manufacturers could not/would not do this properly,doesnt’t mean they couldn’t find somebody to do it,isn’t it? I mean it’s not the same finding someone to do 5 pieces or 500?
Just a slice is not that hard but it makes ugly yellow corona. If you want to do it like me to remove yellowness from corona it takes almost half an hour per led to make it right. That will raise the manufacturing cost very much plus it has high risk killing leds.
Sofirn pls give us some news of this one either good or bad.
Mark me down for something that at least doubles if not triples the Q8. Otherwise 50% more isn’t worth it.
Prefer the 21700…but should come with them. Also USB rechargable. My current charger can’t go past 650 and yes, I can buy outside stand alone connector for the 700s, but obviously slower.
Your not gonna get any of that in this thread. Sorry. You would need a completely different battery design than a 2S.
I thought we were talking about the SP70? And equivalent to the LR40R.
If so, then why a different battery design? Three or four 21700 should have enough current.
I’m a bit confused….
SP70 and LR40R are completely different.
I will have to keep an eye on this. Looks very interesting
any news on this one ? its awful quiet for some reason…
Agree Sofirn didn’t give any info lately very strange wish the history of Kronos K70 not happen again
I wonder if after Chinese New Year, there’s been a rush to fulfill orders that have been piling up. Not showing up here could well mean that they’re too busy working on the SP70 too.
