Infinitely Variable Brightness 1 x AA Headlamp 1050Lumens
75 posts / 0 new
ACEBEAM
ACEBEAM's picture
Last seen: 7 hours 12 sec ago
*Acebeam released 1 x AA Mini Headlamp H40
There are available 2 version CREE XP-L HD LED cool white and SST-20 CRI 95+ LED warm white for option. Let’s view more:*
Features:
Option 1:
1.1xCREE XP-L HD LED
2.Powered by 1xLi-ion (700mAh)/ Ni-MH (1900mAh) / Alkaline battery (excluded)
A)1xLi-ion (700mAh) battery:
Ultra-Low: 5 lumens; 17 hours
High∞Low: 230∞20 lumens; 65 mins ∞ 7 hours
Turbo: 1050~350 lumens; 1min + 40 mins
SOS: ~, 12 hours
B)1xNi-MH (1900mAh) battery:
Ultra-Low: 5 lumens; 43 hours
High∞Low: 230∞20 lumens; 85 mins ∞ 16 hours
Turbo: 250 lumens; 80 mins
SOS: ~, 18 hours
C)1xAlkaline AA battery:
Ultra-Low: 5 lumens; 52 hours
High∞Low: 230∞20 lumens; 68 mins ∞ 19 hours
Turbo: 250~130 lumens; 2 mins + 70 mins
SOS: ~, 7 hours
3.Max output up to 1050 lumens
4.Max running time 52 hours
5.Max beam distance 102 meters
6.Peak beam intensity 2600cd
Option 2:
1.1xSST-20 CRI 95+ LED
High∞Low: 150∞20 lumens; 65 mins ∞ 7 hours
Turbo: 600~220 lumens; 1 min + 40 mins
SOS: ~, 12 hours
High∞Low: 150∞20 lumens; 85 mins ∞ 16 hours
Turbo: 180 lumens; 80 mins
SOS: ~, 18 hours
C)1xAlkaline battery:
High∞Low: 150∞20 lumens; 68 mins ∞ 19 hours
Turbo: 180~100 lumens; 2 min + 70 mins
SOS: ~, 7 hours
3.Max output up to 600 lumens
5.Max beam distance 106 meters
6.Peak beam intensity 2832cd
7.Impact resistance: 2 meters
8.Waterproof: IP68
9.Size: 64.7×26.9×23.4mm
10.Weight: 34g without battery
11.Single button switch for controlling infinitely brightness
12.Constructed from Aero grade Aluminum Alloy
13.Robust HAIII military grade hard-anodized
14.Confirmtable Elastic Headband with sweat channeling and reflective
15.Over-heat protection to avoid high-temperature of the surface
16.Toughened ultra-clear glass lens with anti-reflective coating, which achieves a 98.3% light transmittance
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 45 min ago
Very nice headlamp with the SST-20 95CRI!
Is there a way you could put this in other flashlights?
Not only does it have very good color rendition, but it throws quite far too.
That means you could put it in small AAA lights, to EDC 18650 lights, to large throwers for photography Smile
toddcshoe
toddcshoe's picture
Last seen: 8 hours 56 min ago
That looks really nice. I just acquired a H03, I would have gotten this if I knew about it sooner. Not a bad price either.
"Everywhere I go, there I am"
zak.wilson
Last seen: 1 week 6 hours ago
I really appreciate there being a high-CRI option. The Samsung LH351D seems like it would be a better fit here though. The SST-20 is very throwy, and the SST-20 version of this has nearly twice the cd/lm of the XP-L version.
The SST-20 would be a great fit in some other Acebeam lights, such as the EC35 and the M10.
Ceilingbounce – flashlight testing and runtime graphs for Android
led4power
led4power's picture
Last seen: 20 hours 36 min ago
What is sleep/leakage current when lamp is off ?
adam7027
Last seen: 3 weeks 6 days ago
I like the idea. What is the CCT for the SST-20 option?
maukka
maukka's picture
Last seen: 10 months 1 day ago
That looks very promising. Getting one as soon as they’re available here. Too bad the lowest mode is a tad high at 5 lumens.
djozz
djozz's picture
Last seen: 33 min 5 sec ago
I love my Thrunite TH20 (with 3000K XP-L swapped in), which this is a clone of (and the Fenix HL23, but that has no 14500 support and no infinitely variable brightness). This is finally competition in the single AA category, and with the new 1000mAh 14500 cell it has serious runtime too.
Still find my TH20 more handsome, and it does not have such a loud headband too Silly
Ryzbor
Ryzbor's picture
Last seen: 1 week 6 days ago
This would be serious Petzl/H03 competitor if it would have a decent moonlight/firefly sub 0.5lm mode that would nicely substitute for the “loved” red mode of the Petzl headlamps. 5 lumens is simply way too much for preserving night vision.
You @Acebeam would sell better if you would listen to the suggestions this community provides for free.
But I guess after posting no one will ever look here.
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 ; Sofrin C01R 660nm, Mf01 Mini Nichia 219B sw35+sw40
djozz
djozz's picture
The lowest mode on the TH20 is 0.14 lumen Innocent
hank
hank's picture
Last seen: 1 day 12 hours ago
Same question. In other words, how long to kill a battery if the light is left turned off?
I realize the marketing accounts won’t know this kind of thing. But this really needs to be a 2-way channel that reaches the engineers/designers.
bansuri
Last seen: 4 days 22 hours ago
Hear us!
This $35 headlamp should span the range from 0.1 to 300 lumens, be available in any tint we demand, be PWM-free, run custom firmware that can easily be reflashed, and we demand a direct line to the engineers who designed this!
Then, and only then, will we consider buying it!!!
OK, just kidding. But be aware, if posting your lights in a flashlight forum be ready for triggered flashoholics going ape over a 5 lumen ultra-low.
And it DOES look like ACEBEAM checks the forums because this is offered in sst-20 95+ CRI
I’ve got one in the cart at illumn, just looking for some more stuff to get it up past free shipping. 1xAA headlamps are handy!
zak.wilson
Thrunite gives you a good low mode. Acebeam gives you a good emitter. Either could do both and immediately become the community favorite.
Freedom
Freedom's picture
Last seen: 2 years 8 months ago
Agreed. I really don’t need anything more in a headlamp than what my Thrunite already provides save a mod or soon to come(?) emitter upgrade…which Acebeam must figure is more than enough to make me forget about a proper low mode.
Wrong.
(Edit: one of their distributors made me forget about ‘proper anything’ by offering 15% off through Amazon versus whoever…‘sold’ to an obvious flashaholic).
Domari Nolo “I Refuse to be Subjugated” (1st Pennsylvania Regiment Flag) https://www.1stcontinentalregiment.org/blank
(Flagguys.com):..and man o man did they ever refuse to be subjugated. These guys were everywhere. They were important in Washington’s siege of Boston. They stayed behind and were the last to leave after covering the main army’s dangerous nick of time retreat from Long Island. They crossed the Delaware with Washington. They were “..at Brandywine, Germantown, Monmouth, and every major skirmish, and battle all the way to Yorktown..” where they fought “the most important part of the siege” according to General Steuben. These guys saw action in every one of the original 13 colonies.
Pavlo
Last seen: 17 hours 8 min ago
Acebeam, can you confirm if the light has regulated outputs?
ActiveAl
ActiveAl's picture
Last seen: 4 months 1 week ago
Just ordered the H40 SST-20 4000K 95CRI from Amazon for $29.80 (no tax and free shipping). I like that the weight is only 34 grams (sans battery).  The Thrunite TH20 is over twice that weight (76 grams).
4000K per the Amazon description linked above.
Freedom
Freedom's picture
Thanks, Al. Good point and price. Not sure who competes at that CRI/output/throw(?)/weight/price point in a headlamp nowadays.
chooma
Last seen: 2 hours 16 min ago
Thanks ActiveAl I just bought the same one…..
Can you link me to some Ni-MH cells please….thanks
bansuri
Woah, thanks for noticing the weight difference, ACTIVE AI!
I’m holding off until I hear something about PWM. I don’t care if a light uses PWM but I’ve gotten some budget lights that it’s hard to tell if it’s pwm or a fast strobe.
(And yes, I’m sounding like the picky flashoholics I described previously but at least get the frequency higher than the <$10 lights!)
ActiveAl
ActiveAl's picture
chooma wrote:
Can you link me to some Ni-MH cells please....thanks
I recommend Eneloops if you can afford them - they have great longevity. This eight-pack of AAs at $18.99 is not too bad.
chooma
That “buy with 1 click” button is dangerous…
Freedom
Freedom's picture
…agreed.
We rightfully complain that OEMs simply don’t ‘get it’ in terms of the most basic of inexpensive features needed to corner a particular market.
Immediately, one of their distributors lops off 15% while using a much more palatable and familiar distribution channel…sold.
With that said and in my opinion, TH20s will remain the suggested choice for relatively inexpensive/give-it-a-try AA headlamp hosts in an ever changing LED market over but one critical feature…low output.
Sucked in again.
ActiveAl
ActiveAl's picture
Just PM'd Acebeam this question:
What type of regulation (for example, constant current or voltage) is incorporated into the HC40? Thanks!
It will be interesting to see what kind of reply (if any) I get.
But note the constant lumen output (except in Turbo mode) per LED for all three battery types.
Doesn't this indicate some form of regulation? It would be nice to know the specifics.
Pete7874
Pete7874's picture
Last seen: 3 hours 42 min ago
Why is ACEBEAM statrting another thread on the same subject? There are still plenty of unanswered questions in the previous one, including my question about runtimes:
http://budgetlightforum.com/comment/1427270#comment-1427270
Freedom
Freedom's picture
Good question and catch.
Perhaps similar unanswered questions or those involving members ever taking control back of this forum have something to do with the following business attitude prevailing in our soon to fail trade negotiations:
https://www.youtube.com/watch?time_continue=1&v=JlkLhVo3PbY
I would keep the significant questions coming until they are all answered in every single thread or expect nothing different.
manithree
manithree's picture
Last seen: 6 hours 6 min ago
Hmm. This might be my first AceBeam purchase. I love everything about my Nichia Manker E03H except long-press for off. Anybody have both and can compare the two?
Edit: It would be nice to have the emitter in the center, instead of offset, better firmware on the AceBeam, and better low modes with a 14500 all look like advantages of the H40 (to me, anyway).
And from what I’ve read, AceBeams are generally higher quality builds than most Mankers, right?
toddcshoe
toddcshoe's picture
Well ya’ll talked me into one. I don’t even need a headlamp. Smile
zak.wilson
I’m skeptical. I suspect Thrunite is giving the weight with the headband and Acebeam is giving the weight without it. Parametrek shows a 1g difference between the two with NiMH battery and headband.
Freedom
Freedom's picture
…at least you didn’t say (here) that you wouldn’t buy it…and then bought it anyways. Facepalm
I’ll put you down for not needing one because you never had one…just because it sounds better. Smile
djozz
djozz's picture
My Thrunite TH20 weighs 43 grams w/o battery. The headband weighs 33 grams.
ActiveAl
ActiveAl's picture
I PM'd Acebeam and they verified that the 34 gram weight given in their description of the H40 is for the flashlight only - not the headband or battery. So I made a gross error stating that the TH20 is more than twice the weight of the HC40. Sorry if I misled anyone into making a purchase of the H40 based on my mistake.  I screwed up.
In a separate PM,. AceBeam answered my question about the type of regulation used for the H40. It's  "constant current."
I have to say that I am impressed at the quick turn around I got from AceBeam on my twp PMs. Looking forward to the arrival of my H40. I will probably end up running it with a Ni-MH battery.
