At direct drive the FET isn’t burning off any voltage, you really can’t get any more efficient then that (at the same current level) with a buck boost because now you have an inductor in series with the LED in addition to a FET, (unless you have a bypass FET). I would like a buck boost, but peak power is kind of the selling point of an Emisar D4. My use case doesn’t require longer run time and I’ll take my zebra if I do require it. I’m not going to say that its worthless to develop a buck boost D4, and I would probably buy one, but I wonder what I would have to give up in size, brightness, etc.
Yes, but at virtually every other output level, a buck/boost tends to be more efficient. And there’s no reason a buck driver couldn’t also have a FET for turbo. It could use whichever power channel is most appropriate for each level. The main drawback would be an inability to ramp smoothly all the way to turbo. Instead, it would have a gap in the ramp when it switches from the top of the buck circuit to the FET.
While trying to reassemble my D4 (after flashing Anduril) one of the e-switch solder pads got ripped off the driver . Is this repairable or do I need a new driver?
Looking at the photo of the driver in the 1st post of this thread, It sure looks like the switch goes to pin 2 on the MCU. You might be able to see the trace between the pad and the switch pin.
I can confirm the pad labeled SW+ is connected to pin 2 of the ATTiny85. The other goes to ground, which pin 4 is a convenient point to connect to ground. Or the adjacent pad of the closest resistor R?.
I’m not an electrical engineer, but I would think eliminating the forward voltage of the FET would provide a significant improvement efficiency. For the D4, I see the number “09NE2LS5” on the FET. From the datasheet I found on that, it looks like it is 0.78V at 30A. This one, like most FETs, shows only minimal improvement in that Vf at lower currents - roughly 0.7V at 4A.
I’ve found the efficiency of the D4 generally fine for my needs though. I wouldn’t view improving further as a high priority.
Eliminating the forward voltage of the FET would definitely improve the efficiency, but the FET is the controlling element for lower light levels also.
A quick web search showed me a FET with 12milli ohm, 50A rating in the package used on the D4. FETs are like voltage controlled resistors, but once they are “on”, they are a fixed resistance. So 0.012V * 30A is 0.36V, and 0.012*4A is 0.048V. Not sure where the measurements above are measuring, but it seems like there is a fixed resistance in series with the FET being measured which is why the voltage does not change linearly with the current. Or, somehow at lower currents the FET is not being fully turned on at the 4A current. If the measurements include PWM and are being done with a digital volt meter, then all bets are off as to the accuracy of the voltage measurement.
Oh, and I am an electrical engineer, but I don’t get to play that role much these days, more of a project lead now. It’s fun to go back and frolic in the math now and then.
The white “grainy” one got really smooth within a week in my pocket. I could experience this again when I started using the short tube. But after 6 or 8 weeks of use, the D4 is just as smooth as my other lights. Just use and carry them.
For speedier results, pass the light back and forth rapidly on somewhat abrasive cloth covering a cushioned surface.
The edge of a felt covered sofa worked for me when needing to smooth the sharp edges of a Jetbeam TCE-1 purchased new at a third the price. Going Gear sold fifty of the titanium lights at 80 bucks each, purchased cheap from Jetbeam due to complaints about the grabby diamond pattered knurling on the tubes.
This has been bugging me since my last post, finally got back to look at this. I realized that you posted the part number and quoted the data sheet, while I quoted a different random data sheet. The part number listed is actually much better than the one I found.
I did not find the data you quoted (on voltage versus drain current), but diagram 6 (on page 8 of the linked data sheet) does plot the resistance of the part versus current from 0 to 50A (part is rated to 100A constant, 400A peak!!) The resistance is very flat for a given gate bias voltage, but does vary for different gate bias voltages. Since the D4 does not have a power converter in it, the gate bias voltage can be no higher than the battery voltage. So the on resistance is like best case about 0.001 ohm (1 milli ohm) but does not vary with the drain current.
I am not posting this to say “I told you so”, but more just to clear um my own thinking on this, and share those thoughts with others who might be interested.
I played around with my SST20 4000K 95 CRI D4 last night and compared it to my XPL HI D4. My impressions of the SST 20:
It is possibly very slightly throwier on a full cell at full power. I didn’t verify with my luxmeter though.
It puts out a lot less light than XPL HI. The hotspot might be marginally brighter, but is a lot narrower than the D4.
I suspect SST20 draws more current than XPL HI. With the SST20, the head got hotter noticeably faster.
Output also dipped a lot faster than with XPL HI. The thermal sensor kicked in to reduce output within 10 seconds. With Anduril installed, and XPL HI I could set my Titanium D4 with bare polished aluminum head (pretty much the worst possible heatsinking combo for a D4) at a max ramp setting of 46 clicks. The light would take quite awhile to ramp down. When I swapped in SST20, I had to set the max ramp at 51 clicks and even then the head still got hot and ramped down within 20-30 seconds or so.
My battery voltage depleted noticeably faster with SST20, also suggesting that it draws more current. Run the SST20 D4 for 30-60 seconds at turbo with rampdown, then let it cool and turn it on next to an XPL HI version and even the hotspot of the SST20 is noticeably dimmer than XPL Hi.
At all lower and intermediate power settings the SST20 displayed an unpleasant greenish tint. The tint is definitely above the black-body line. I found lower power on my XPL HI D4 to be much more pleasant and didn’t look greenish. This is a shame, because at turn-on on max-turbo the green isn’t evident and the beam looks great.
Having tried the SST20 4000K 95 CRI side-by-side with 4000K 5D XPL Hi, I have now concluded that XPL Hi is much superior. The benefits of higher CRI and lower cost from the SST20 are massively outweighed by the XPL Hi’s benefits of better color temp, higher peak output, higher sustained output and longer battery life.
