I wanted to do a mod with the pink led first, to post with the led-test, but I may skip that and just post the test one of these days (but not now because I’m off to bed in a moment).
PC-amber is very similar but a bit more orange. I just measured a PC-amber flashlight (with a ProLight PC-amber led) and the peak in the spectrum is just a bit more towards red, colour temp is 1900K. The CCT btw is, just as the yellow one, way above the BBL. Left the yellow hotspot, right the PC-amber hotspot:
It probably depends on Luminus. I think it makes sense that now that they started with the other cool and neutral 70CRI CCT’s of the SST-40, but not 4000K and warmer, that at some point they finish the SST-40 line-up with warm 95CRI versions. One can hope, right?
Whats up with the Giant Gangster Whitewalls on the chick bike, Is that a happening fad over there for cyclists or a safety thing? The Yellow Bile colored beam really makes them POP!
It is very common to have a reflective strip on the tire over here, it helps a lot with safety. But this particular bike seems to have reflective rims instead.
Same bike in daytime:
There you go ^
It would make sense if the behaviour was similar to the yellow one but it seems a quite different led. It did not even die at 10A when I stopped the test.
I made an S2+ shorty with BLF-A6 driver to check the led. It is indeed very pink and puts out 400 lumen on a 18350 battery. With some bypasses and such it should do over 600 lumen.
Not an Epiled, but got some “bead” type pink LEDs offa Amazon. They’re pretty interesting. Got one in a drop-in, which ended up in a pink/purple/whatever ’501 that I got offa FT.
