Interested!
I hope to get news before the CNY
When is the expected release?
CNY is only a few more weeks. Feb 5th this year which is a Tuesday. Last day of work will probably be Friday Feb 1st.
+1 … Please try to get them to NOT glue the bezel Martin. AND to use a minium amount of glue on the driver.
I’m in for one…
Im in for a NW or warm emitter. Hopefully not too much glue : )
I’m in.
€dit got the
Specifications
Emitter: Cree XP-L High Intensity, neutral white or cold white, mounted on copper DTP MCPCB
Flux: ~1000 lm
Throw: ~400 m & ~50Kcd
Firmware: Tom E’s open-source GPL NarsilM v1.3 adapted by Texas_Ace
User interface:
[1] By default the GT micro is set to use the very intuitive Narsil smooth RAMPING UI. Instant access to a 2.5 A TURBO mode is also provided.
[2] A more conventional discrete level MODE-SET UI is available as an alternative. Any one of 12 predefined mode-sets can be selected.
[3] MOMENTARY mode is useful for signaling purposes or rapidly/briefly lighting up targets.
Battery: One 14500. Cell is not included.
Driver: Texas Avenger FET driver
Reflector: 29 mm ID, aluminum, smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Button: Tactile with back-lit rubber boot
Ingress rating: Equivalent to IP65, do not immerse in liquids
Weight: Approximately 70g without cells
Dimensions: 36 mm Ø head x 105mm length
Link to the groupbuy: https://m4dm4x.com/lumintop-gt-micro-interest-list/
So once again they chose not to take any risk and go for an already BLF brewed TA driver with only li-ion… it’s a shame, I’d love a Ni-MH powered Narsil driver.
Anyway, this will be a best seller
EDIT : an SST20 would have been a better choice IMHO, smaller die, better tint and lower price
the AA/NiMh + 14500 driver was not near "good"
- 14500 turbo only
- in aa just 250 lumen
- very high parasitic drain
- some other downs
i am glad they skipped that ;)
SST20 option is not off the table ;)
Looks good , I can’t wait.
I hope for a GT nano light next.
Thanks for the specs update Martin, form completed.
Can you ’try’ to influence them to NOT glue the bezel……
I already did teacher ;)
:+1: … Thank you sir, hopefully they will listen.
Form filled for 2 NW versions. This little light will be awesome.
Take my money! Almost a quarter-mile of throw in such a small light I’m stoked!
If & when you can find out, let us know the CCT of the Neutral White & Cold White please.
Add one if SST-20 is added; protected battery fitment only.
