I’m skeptical. I suspect Thrunite is giving the weight with the headband and Acebeam is giving the weight without it. Parametrek shows a 1g difference between the two with NiMH battery and headband.
I PM'd Acebeam and they verified that the 34 gram weight given in their description of the H40 is for the flashlight only - not the headband or battery. So I made a gross error stating that the TH20 is more than twice the weight of the HC40. Sorry if I misled anyone into making a purchase of the H40 based on my mistake. I screwed up.
In a separate PM,. AceBeam answered my question about the type of regulation used for the H40. It's "constant current."
I have to say that I am impressed at the quick turn around I got from AceBeam on my twp PMs. Looking forward to the arrival of my H40. I will probably end up running it with a Ni-MH battery.
Your assumption of my never having a headlamp has failed you. I have headlamps. Not this particular one but, I have a few. I don’t have a AA/14500 headlamp. Might use them more often if they didn’t feel like I actually strapped a 18650 light to my forehead. So my sentence of, “I don’t even need a headlamp” did in no way convey that I never had or currently have one.
The first thing I did after unboxing my H40 today was weight it on my kitchen scale. The flashlight (sans battery) weighted 37 grams, and the headband weighted 45 grams - for a total of 85 grams.
The headband is very beefy and hold the flashlight well. I've only worn the assembly a couple of minutes, but the flashlight seems almost unnoticeable on my forehead - which is going to work well for me.
Sorry to hear that. Hope that the turbo output makes up for it. I must have lucked out on the Thrunite TH20 and chose a different LED (if there was a choice) as It isn’t bad. Anything else that you don’t like?
