I think they should be able to get good parts. If not though, the effect would be a bit of change in brightness while changing tint:
With ideal parts, brightness should stay rock-steady while adjusting tint, like a flat board placed across two support beams.
With lower-quality parts, particularly with slower activation times, brightness would sag a bit at middle tints, like a cable strung between two telephone poles.
Given how visual perception of brightness works though, even the non-linear version would probably be a pretty subtle effect. And if it shows up in testing, perhaps the firmware could try to correct for it.
I'm finding the light manufacturers (Sofirn, Emisar, FireFlies, Amutorch) seem to be getting the good 7135's, but I can't seem to find them to buy stand alone. Usually it's the opposite case - go figure...
Id love a good source of 7135s. The ones recommended by Lexel from LCSC turned out to be the low quality ones, the raptor claw ones. For what ever reason Richard’s seem to be a good supply but aren’t bulk friendly. And they are out of stock (fast 350mA).
I can give my experience from my candle project. Having tried a few varieties the tint mixing firmware is more sensitive to poor 7135, as it stands now. with PWM values at the floor of 1 the poor 7135 do not turn the LEDs on. Setting the floor to say 5 and changing every other value below 5 would result in the light turning on at 5 then dimming and turning off before turning on again. The tint mixing is causing it to go somewhere below 5 even when it is running on one tint channel entirely.
Interesting observations. I understand that those issues are only at the lowest levels? So to obtain a very low level intermediate tint you have to raise the floor a bit so that the end tints are a bit too high and the in between the tint is as low as wanted? or ramp up a bit.
I suspect a less noticeable, related issue happens at higher levels. From testing HKJ did, and that I later replicated, cheap 7135’s seem to activate too slowly to maintain regulation very well, depending on the duty cycle and input voltage.
I don’t think I ever posted my findings to BLF, so excuse the external link. HKJ’s first post has lots of specific graphs. My post near the end of the discussion has a single, simpler graph overlaying tests at 3 duty cycles: 100, 25, and 3%.
I experienced very good regulation at 100, mediocre regulation at 25, and no regulation at all at 3%.
So this suggests cheap 7135’s would result in (probably subtle) tint changes as battery voltage drops, in addition to the issue staticx57 already noted when one channel is at low output.
Unfortunately, the linking in the opposite direction is much more frowned upon at CPF. I suppose I should at least post the same content to HKJ’s identical review on BLF.
Ill add a bit more of my observations if it may be helpful on this project too.
Ill add I have tried three separate types and batches of 7135s. My Candle uses the tint mixing firmware as well so I figured it would be uniquely helpful here. Anyways.
The first 7135s I tried were from Richard and were marked 7135 35L with nothing else on them. The way the tint mixing firmware is by default includes a minimum PWM value of 1. These 7135s worked perfectly fine and had no issues. I can ramp both channels and they both worked and all of the intermediate mixes worked just fine too.
The next batch of 7135s I tried were from LCSC and were the “raptor claw” ones as suggested by Lexel. These particular 7135s had no interested in turning on with a PWM value of less than 5. Set the ramp to a minimum of 5 and they kinda turn on but any mixed value ends up turning them off when we are mixing channels. Even with this, turning on in moon in single channel no mixing then ramping UP turned the light off again then on even though I never set a value of less than 5 in the ramp. Setting the PWM values to around 15 seemed to correct the problem as it would always be on but the ramp was still wonky as in turn on moon would be brighter than a bit up the ramp then it would get brighter again. Made no sense to me as the PWM values were constant. This affected the special modes as well. I ended up throwing these 7135s in the rubbish.
My last batch are Richard’s 380mA with the shark fin. These flicker on PWM value 1 but I raised the the 1s in the ramp to 2 and they seem to be ok. This minor changed seemed not to affect the firmware either.
