Infinitely Variable Brightness 1 x AA Headlamp 1050Lumens
…looking forward to both of your thoughts. I like the ramping on my TH20 after getting used to it. Easier to explain to somebody borrowing it as well.
The first thing I did after unboxing my H40 today was weight it on my kitchen scale. The flashlight (sans battery) weighted 37 grams, and the headband weighted 45 grams - for a total of 85 grams.
The headband is very beefy and hold the flashlight well. I've only worn the assembly a couple of minutes, but the flashlight seems almost unnoticeable on my forehead - which is going to work well for me.
I’ve removed some bulk from the whole setup. I just removed the top headband strap. Doesn’t seem necessary for such a small light.
Yeah it seemed odd…glad you cant take it off.
The XPL HD is a nasty tint…just like the Thrunite…SMH, ON Turbo its not to bad…but high and below is nasty.
I agree but If I had to pick one ..
I'd let my eyes adjust to light rather than pick a light my brain has to try to adjust to ...but yeah ...both.
I like the look of it .Now I need to stop looking .
Sorry to hear that. Hope that the turbo output makes up for it. I must have lucked out on the Thrunite TH20 and chose a different LED (if there was a choice) as It isn’t bad. Anything else that you don’t like?
…any feelings on how it throws, tint, low mode, etc. (thanks).
Yeah it blows, might get the SST20 Version.
(Brainsick)“…Yeah it blows, might get the SST20 Version…”
I’m unsure that the SST20 version is any big deal to the budget community at large given little to no LED specific video that I can find describing that light in detail to date. There must be a good number of single AA higher CRI/throwy headlamps out there with infinitely adjustable current generation LEDs fitting protected batteries from a well known manufacturer for $30 delivered.
Heres my Crappy Unboxing.
]https://m.youtube.com/watch?v=-M05lF2z4_s
I enjoyed your review, and subscribed to your channel. Thanks for the frank assessment about the XP-L HD tint.
I must say that the 4000K tint on the H40 with SST-20 LED is pretty good. It is warm and appealing but not quite as rosy as the Enogear SS AA/14500 IMO. However, the H40 does not have the same level of obvious PWM as the SS AA/14500. (My method of measuring PWM is rather primitive - I just wave the flashlight in front of my eyes. I noticed no PWM with the H40 using this method, but it is obvious with the SS AA/14500.) Edit. My PWM assessments were done using the lowest available flashlight modes.
The OP lens on the H40 offers a surprising amount of throw in Turbo mode. The beam has a tight spot with a large area of spill. In UltraLow and Low modes the beam with the H40 is more homogeneous without spill. So far I have only used a 14500 battery, but will eventually try a Ni-MH.
(deleted)
I very much appreciate the video along with the commentary from both of you. If the output is impressive when the XPL-HD is tested outdoors and Al’s assessment is agreeable to most then these seem to be 2 of the 3 lights to beat in a fairly broad and admittedly undefined category of higher output/throw AA/14500/NiMH protected cell headlamps/EDC torches at $30 (whew).
is it easy to open up and swap emitter?
">https://m.youtube.com/watch?v=-M05lF2z4_s
[/quote]
Thanks so much for watching/ and subscribing…i didnt notice PWM, I do the same test as you do…i will test when i get home.
Thanks man…i want a good light like this…i will test it against the Thrunite TH20 when i get home…i got both CW and NW, both Tints arent good…
I’m hoping that it’s a winner too. If it’s easy to mod as has been apparently done with the TH20 (never have but should be able to with the help here) then the H40 might satisfy for quite a while. I’ve been blessed with (4) protected cell 14500 lights or headlamps that put out 500 lumens or better in various tints/CRIs (ZL SC52, UT01, TH20 and soon this H40 in SST40). Only the ZL was relatively expensive and all seem to reach out farther and perform far better than I would have ever expected not that long ago.
In other words, I’m pretty satisfied with where the smaller cell format has stalled…and that may be a good thing until protected 21700 lights (if ever) start to become more popular…and the problem starts up again. :person_facepalming:
Where can it be purchased?
Illumn has them in the US. Nkon has them in the EU. This reddit post has a teardown - emitter swaps look very easy. LH351D would make a lot of sense here, I think.
