*BLF LT1 Lantern Project) (updated Nov,17,2020)
Add me to the interested list, please! Excited for it!
I suspect a less noticeable, related issue happens at higher levels. From testing HKJ did, and that I later replicated, cheap 7135’s seem to activate too slowly to maintain regulation very well, depending on the duty cycle and input voltage.
I don’t think I ever posted my findings to BLF, so excuse the external link. HKJ’s first post has lots of specific graphs. My post near the end of the discussion has a single, simpler graph overlaying tests at 3 duty cycles: 100, 25, and 3%.
I experienced very good regulation at 100, mediocre regulation at 25, and no regulation at all at 3%.
So this suggests cheap 7135’s would result in (probably subtle) tint changes as battery voltage drops, in addition to the issue staticx57 already noted when one channel is at low output.
A CPF link, on BLF?
Are you TRYING to get banned?!
(Just kidding!)
Unfortunately, the linking in the opposite direction is much more frowned upon at CPF. I suppose I should at least post the same content to HKJ’s identical review on BLF.
Ill add a bit more of my observations if it may be helpful on this project too.
Ill add I have tried three separate types and batches of 7135s. My Candle uses the tint mixing firmware as well so I figured it would be uniquely helpful here. Anyways.
The first 7135s I tried were from Richard and were marked 7135 35L with nothing else on them. The way the tint mixing firmware is by default includes a minimum PWM value of 1. These 7135s worked perfectly fine and had no issues. I can ramp both channels and they both worked and all of the intermediate mixes worked just fine too.
The next batch of 7135s I tried were from LCSC and were the “raptor claw” ones as suggested by Lexel. These particular 7135s had no interested in turning on with a PWM value of less than 5. Set the ramp to a minimum of 5 and they kinda turn on but any mixed value ends up turning them off when we are mixing channels. Even with this, turning on in moon in single channel no mixing then ramping UP turned the light off again then on even though I never set a value of less than 5 in the ramp. Setting the PWM values to around 15 seemed to correct the problem as it would always be on but the ramp was still wonky as in turn on moon would be brighter than a bit up the ramp then it would get brighter again. Made no sense to me as the PWM values were constant. This affected the special modes as well. I ended up throwing these 7135s in the rubbish.
My last batch are Richard’s 380mA with the shark fin. These flicker on PWM value 1 but I raised the the 1s in the ramp to 2 and they seem to be ok. This minor changed seemed not to affect the firmware either.
Thanks for the input and suggestions on the 7135s, much appreciated. Hopefully the manufacturer can get the correct ones.
I signed up to say I’m interested in 1 or more of the lanterns depending on price as well. Very exciting!
Welcome to the BLF forums!
Try doing that over at CPF
Interested in one of these. Put me on the list please.
I’m waiting on prototype hardware before I try to adjust anything about the tint ramping. It could be fine, or it could need some tweaking. We won’t know until after doing some tests.
Hi,
Nice work, I would be interested in a production model.
I’m interested! And excited to have finally signed up to BLF!
Someone please get this girl some hardware! Uhh, that didn't come off as I meant, oh boy....
Wow, a run on these lights last night! Welcome to BLF JermsMalibu, Canard, and PreacherCasy. :beer:
Here is the next group of names to update the interest list in the OP.
1181 Jorrail
1182 Jorrail
1183 DrinkingJar
1184 ramius
1185 sc00ts19
1186 sc00ts19
1187 jonxxn
1188 TheLonelyLumen
1189 Td398
1190 JermsMalibu
1191 lightboks
1192 Canard
1193 PreacherCasy
interest list sorted by entry number
interest list sorted by user names
Added :slight_smile:
This project looks fantastic!
Please add me to the list. I’ll most likely be in for 3/ea
Thanks!
Hi.
Add me to the interested list.
Thanks.
will do, welcome to BLF Orodizi and mattadores! :beer:
Interested in one.
