Yeah, Iâve heard about that, but the boots on mine protrude no matter what, just worse when theyâre off, because they seem to be bulged in the middle. Not the case with the Tool, the boot on it is perfectly flat.
Oh yeah, that has been a complaint before by some. I donât remember any exact references to give links to because I paid it little attention. But I have read it several times in the past three years about various different lights.
Regarding the mod-ability of the Tool AA 2.0, I belive that the head assembly would come loose pretty easily with a good pair of thin snap ring pliers.
Unfortunately my own pliers have quite thick endpoints so they wonât fit into the driverboardâs holes.
EagTac D25A shows how to do it. Still no full circle, but almost. Along with a low profile switch this is the perfect solution to tail clicky candles. Anything less isnât really working very well; They could as well have omitted the ring completely, having an all around accessible switch (like Armytek). I dislike compromises that doesnât work well in either way.
It will. If itâs too long, just add a circle of paperclip or metal wire in the tailcap end. The threads are quite long and it takes virtually any cell from factory.
My snap ring pliers seem to be coated / hardened, so a metal file will do minimal damage.
I would preferably use an angle grinder than start filing for 2 hours
Just received my Lumintop Tool AA V2.0 from Amazon. First of all the tint is pure white. Second it is bright. Very bright just using an eneloop battery. It makes the V1.0 seem to have only moon modes. Very pleased with my purchase. Recommended.
Some people give one star because they think the price is too high.
Some give one star because delivery took too long.
Point being, many people donât review the product itself.
[quote=264]
You knew when you know what you bought.
That sounds bad so let me explain.
The light itself is good. Everything promised is in the package. The output and runtime are as advertised. Itâs also really waterproof (I tested that in my bathtub). Build quality is good.
But yeah that doesnât mean you will like it. You could for example hate the tint. Some people on Amazon rate the light because the light has exactly the tint they ordered, but simply donât like the tint.
The AAA and AA version were my fist small and tiny lights. I like them and as for me that means a new search starts for a better replacement. Aspheric lens and high CRI for example.
Based on the good feedback, I just ordered one to add to my growing collection of 14500 lights. The smaller lights are impressive and just plain cool to me. Perfect for my use inside the house, in the garage, and will even do for the backyard, though I prefer my C8s for outside. With the new Vapcell 1000 mAh battery, run times should be good.
In my experience most of the 1 and some 2 star ratings are either donât know how to use, or unrealistic expectations. There are a few outright failures, and if there are too many of those I move on.
Check out the Sofirn C01 in their Aliexpress store. AAA, Yugi high CRI, 60° beam angle for nice even beam, choice of 3400K/5200K emitters. And a sub $10 price.
Thatâs correct.
The Vapecell 14500 is one of the best in its category.
Itâs highly likely that you will even get a better turn-on lumen performance
Thatâs something I forgot to mention.
Indeed there is no LVP. To my knowledge, it quite a common practice on flashlights that use a boost/fet driver and accept both NiMH and LiION cells.
