My snap ring pliers seem to be coated / hardened, so a metal file will do minimal damage.
I would preferably use an angle grinder than start filing for 2 hours
Just received my Lumintop Tool AA V2.0 from Amazon. First of all the tint is pure white. Second it is bright. Very bright just using an eneloop battery. It makes the V1.0 seem to have only moon modes. Very pleased with my purchase. Recommended.
Some people give one star because they think the price is too high.
Some give one star because delivery took too long.
Point being, many people don’t review the product itself.
[quote=264]
You knew when you know what you bought.
That sounds bad so let me explain.
The light itself is good. Everything promised is in the package. The output and runtime are as advertised. It’s also really waterproof (I tested that in my bathtub). Build quality is good.
But yeah that doesn’t mean you will like it. You could for example hate the tint. Some people on Amazon rate the light because the light has exactly the tint they ordered, but simply don’t like the tint.
The AAA and AA version were my fist small and tiny lights. I like them and as for me that means a new search starts for a better replacement. Aspheric lens and high CRI for example.
Based on the good feedback, I just ordered one to add to my growing collection of 14500 lights. The smaller lights are impressive and just plain cool to me. Perfect for my use inside the house, in the garage, and will even do for the backyard, though I prefer my C8s for outside. With the new Vapcell 1000 mAh battery, run times should be good.
In my experience most of the 1 and some 2 star ratings are either don’t know how to use, or unrealistic expectations. There are a few outright failures, and if there are too many of those I move on.
Check out the Sofirn C01 in their Aliexpress store. AAA, Yugi high CRI, 60° beam angle for nice even beam, choice of 3400K/5200K emitters. And a sub $10 price.
That’s correct.
The Vapecell 14500 is one of the best in its category.
It’s highly likely that you will even get a better turn-on lumen performance
That’s something I forgot to mention.
Indeed there is no LVP. To my knowledge, it quite a common practice on flashlights that use a boost/fet driver and accept both NiMH and LiION cells.
Mine tail stands just fine. I even tried a little nudge perpendicular to the open portion of the ring and it settled right back to upright.
And I don’t believe the Tool AAA ever claimed to be able to tail stand just for that reason. [You can always just stand it up in a shot glass. Not totally vertical but still ceiling bounces just fine.]
Does anyone know where I can find an electronic version of the user manual. I like to keep electronic versions when I can because my paper manuals all seem to disappear. I usually put them back in whatever container the light came in then store that somewhere, and promptly forget where that was.
If you really want a Tool AAA to tail stand, just get the magnetic tail cap. You loose the push-button option so it becomes a twisty only, but the magnetic tail cap is flat, and allows the Tool AAA to stand just fine.
