Lumintop GT4
Sadly it is not possible due to the way the machining works. It has been tried many times but it is simply not possible to make it line up without a lot of manual labor to grind each piece individually by hand pretty much.
Is the intent to do a GB on this light?
:person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ………… :person_facepalming: ……… :person_facepalming:
+1 & Amen… :+1:
Very nice…
Interested!
Can't the flats be set to line up with the button by loosening the battery tube slightly until they line up then tightening the tailcap holding it in place? At least that what someone else recommended long ago and I have did ever since. Of course, that won't help to line up the strap attachment point.
How 'bout some nice auxiliary LEDs? Would that be feasible like in the D4S or E07?
Lux-Perpetua cool idea they should do it, there is place for it :smiley:
Something like the charging indicator in the Convoy BD01 would be coll too.
They use transparent centering-pieces with path through the MCPCB and shell to a LED on the driver.
You can see it here:
That BD01 indicator is nice!
What about having more length on the tube thread, so users can grind down a quarter or a half turn by themselves?
The battery tube can be indexed to any position you want on the GT and GT70, the anchor point on the head was the main complaint.
Ah thanks, now I remember.
I’m in for one.
+1
Yes, this is what I do with my battery tubes. Like KB said the head sling point is the one that can’t be indexed.
Interesting idea, although it would be a lot more complicated then it sounds to actually do it.
Plus Narsil does not support separate LED’s, so the best it would do is be a copy of the side switch LED in function.
I can ask about it though but I am guessing it would increase the price which is already going to be a possible issue.
Hhhmm. Think'n if we got a spare pin on this driver, I could add support for a 2nd AUX LED(s), but may be a bit involved.
Forget how the buck driver support works - if 2 pins, then maybe can't work.
5 available I/O pins:
  • switch
  • AUX LED
  • 2S required voltage divider input
  • 1 or 2 output channels (FET+1 is 2 pins)
