I just received my GT Mini NW from Lumintop Aliexpress store and I am so happy with it I cant even express it with words!Extremely well build very handy pocket thrower with perfect Kelvin emitter for me!Wicked flashlight!
great!
I just received one also. I am really happy with the light! The size, the distance the beam throws, the tint of the emitter, the UI. Pretty cool that I have a light similar to the BLF GT that I can carry in a pocket. I love BLF! Thanks to all for the effort. Regards.
Same from me man!All the lights BLF community makes are great!
I cant wait to save money for the bigger brother of GT Mini,but I am not sure which to get GT or GT70,maybe the 70 is more of a usable beam
Two comments:
1. I sometimes have a problem turning the light off. Usually if I try a few times or ramp up a little ways then try it will work. Not a big problem so not worrying about it.
2. Got mine from Banggood. I ordered a neutral white emitter, received my light with a big CW sticker on the box. I informed Banggood, and their response was basically, ‘mistakes happen once in a while. Will you accept 400 Banggood points [$4 USD] to make it all better.’ Not really - I ordered a neutral white because that is what I wanted.
Anyone have any suggestions on best next step?
Next step to what?? Not trying to be funny, I just don’t understand. Are you asking about #1, #2, or both??
Just don’t agree to anything that doesn’t satisfy you. They just offer silly coupons and wait to see if you’ll escalate it.
My light had really bad paracitic drain when off, I’m talking an order or magnitude higher than it should of been! It was drawing around 1100-1200 micro amps while off. Not a new development but I just now finally got tired of it and decided to do something about it.
I removed and replaced driver components one at a time (do note I’d already deleted the unnecessary voltage divider since the tiny85 monitors cell voltage internally) till the draw went away. The culprit: C1
I’m now measuring 37uA with the aux LED off, 137uA with it on high (blue led with 5.6kohm R6). I can finally leave the tailcap not locked out again!
Also swapped to the good FET and swapped to a SST20 while it was apart. Reading 156kcd now @ 1300Lm.
You think the C1 had a crack internally which caused a small short? Maybe just defective from the start?
Is it actually possible to order a GT mini without the bezel glued? I’m getting rather sick of manufacturers that work with BLF surprising us with glued parts on the production run. Enthusiast lights should never be glued.
Lumintop, you have a lot to answer for
What is that? Glue on the threads, crappy anodizing, crappy threads, or what??
That’s blue Loctite, which makes removing the bezel a huge pain in the ass.
OK…. That’s what I thought but could not tell for sure from the pic.
I just gave up on getting mine off… it was not worth the trouble to me.
I can’t understand why they would use that much…… that is total & complete overkill if they are going to use it.
If it is a BLF light I wish they would stop using any glue or LockTite at all.
Maybe if we start voting with our wallet, they will.
mine will be here tomorow unless the storm stops ups i am so excited
That’s normal.
Here’s my glued ODF30.
They said it was glued, so they have nothing to answer for.
Hello, I just purchased a GT Mini and will receive it today.
QUESTION: Are IMR 18650s or 18350s batteries okay to use in it?
thanks!
I have a Samsung INR18650 30Q in mine, and it works just fine. I would look for documentation saying it would be OK before using two 18350s, due to the higher voltage than two CR123s.
yes high drain 18650 recommended, and 18350 will work if using the shorter tube.
Mine was glued with a bunch of thread locker too. Two strap wrenches and the bezel was off in a minute. Used naptha to clean it up.
