It is 5 minutes epoxy similar to JB weld but it hardens in 5 minutes. So yes this stuff in picture is done in 5 minutes
Abro steel epoxy. Permanently. No repair here like with fujik or above mentioned stuff. looks similar to this one(athough my package bought locally looks bit different):
I used all kind of epoxies and probably 2 most famous ones(uhu endfest 300 and JB Weld), but this Abro one bought me Done in 5 minutes!
Edit:
How can I rework this driver to single mode only(high or turbo only)? But I want of course that reverse polarity protection works after mod. Pretty please guysā¦
You can compile the code for whatever pinout you need however the easiest thing to do would just be to physically jumper(short with solder) pins 5 and 6 on the attiny.
But when I short the two pins, I canāt use the 7135 for a moonlight/ low mode. I really looking for someone who have modified the firmware to work. Iām still trying to get it to work by myself by changing the firmware (and testing with trial and error because I donāt have any programming skills :p)
Also the screenshot for the minimalist driver posted by Major (in beginning of this thread) shows only half of the required code. So I canāt use that either.
Yes FET+1 (with ATTiny13A )
Someone else in this thread posted this drawing and itās actually the same as the drivers I use. So I presume I need to program that the FET uses pb0 as output.
I could only flash blf-a6-13-rmm.hex (but it also uses the wrong chip layout). The other hex files are also too big to flash for an atiny13a. When I try to compile it, I have to delete a lot of code and then itās still 3% too bigā¦
Maybe I can edit pilotdog68ās xintd-x3 firmware, itās within the attiny13a size range and I donāt need to include other filesā¦
But I experimented a bit further with the xintd-x3 firmware and I think I have solved my problem.
By changing the input at the following fields: define PWM_PIN, define ALT_PWM_PIN, define PWM_LVL, ALT_PWM_LVL. By swapping the pb0 & pb1 and again swapping OCR0A & OCR0B
Most all of our BLF firmwares require optimization settings for size.
Its a preference setting in atmel studio that effects how the code compiles. I donāt know enough to know what it actually does or explain it, just enough to know what to set it toā¦
Oke I will look into it. But for my regular Nanjg 105C drivers I still use the luxdrv (really easy to personalize and has everything I need).
Is it normal I only get 3,4 amps on the max setting? I used the PH4030AL FET in combination with a Sony / Murata Konion US18650VTC6 3120mAh - 30A cell. With cheap cells I only get 2,2 ampā¦
Also replaced the leads with some ticker ones, without any effect. Wil try a spring bypass just to be sure.
No, not if you want a 5A current limit regardless of led voltage or battery type/charge state. You could add a resistor in the circuit (maybe in the form of thinner longer ledwires) but that would limit current at all modes, not just over 5A, it does not regulate.
What you hope for is current regulation and that is what the original 7135 chips on the original AK-47 driver did (3 chips for 1.05A), and for 5A you need 14 of them . Similar current regulator chips that regulate more than 350mA do not exist (maybe because of overheat problems in such a small sot23 package) or are not suitable in this application.
The way to go for you may be using a different type of FETās that can regulate the current instead of just switch on and off. Led4powerās drivers are like that but are not as cheap as these NANJG drivers. A relatively new solution that you may check out are the 5A Convoy drivers, 1.12ā¬ 83% OFF|17Mm Driver Voor SST40 ,4 Modi 0.1% 3% 30% 100%, max Huidige Output 5000mA, Temperatuur Bescherming Management Binnen|Zaklampen| - AliExpress , they are 17mm, regulated at 5A, have 4 simple modes and memory, and have lightweight low profile components that just may survive rifle recoil pretty well. And they are cheap, 5 drivers for 16 dollar.
I really hoped there is a way to restrict current on this driver for certain applications like OSRAM leds cause I have hundreds of them(ak47c1) and since they have proper mode order for mine application(c1 firmware, it always starts on high mode).
While thinner wires are not suitable for mine build Resistor in a circuit sounds good but I really donāt know where to place them and what resistors should I buy? I hoped you could show that?
With FET drivers we use high current cells like INR30Q so this Djozz FET driver should be modded so it canāt pull more than 5A of current in a setup with INR30Q and Osram WF emitter. Probably with proper resistor this is doable?
Convoy drivers unfortunately does not have suitable mode order for hunting purpose low>high. And I really donāt need regulation for 1x18650 cell setup. Short burst of turbo is all I need.
For guns / rifles you need a fat rubber or even plastic ring around the battery spring, as a bump stop, like in car suspension (for the same reason)
It will prevent spring crush and PCB impact.
Yes, luminarium iaculator, get that driver from Simon, for Peteās sake.
Doesnāt it have mode memory?
Simple spring bypass with 18AWG wire acts like a bump stop and perfectly presses flat top battery to Djozz FET driver spring(which is also bypassed with 22awg wire). Holds heavy centerfire magnum recoil without any issues.
I would order from Simon but I donāt like mode order.
And I still hope that there is some kind of resistor that can be added to this Djozz FET driver which would restrict current draw to not more than 5A with INR 30Q and OSram WF
A tough rubber ring around the spring moves the force from the center of the driver PCB to the rim, so it wonāt bend or break.
Itās a simple mod.
You can cut a ring from rubber hose, or even garden hose or something similar.
It will also reduce the impact on the battery itself.
Thanks for rubber ring idea but in mine mode there is no impact on battery at allā¦ Once when you put the bat it stays firmly in place.
During few years I done hundreds of them without any issue. No need for rubber :), although we really do know that proper rubber is really needed for certain applications
