Fireflies ROT66 Flashlight
974 posts / 0 new
iamlucky13
Last seen: 1 day 11 hours ago
JasonWW wrote:
i42dk wrote:
My ROT66 with AUX LED’s, cant switch off the AUX LED on the emitters.
Only difference 7-clicks does, is switch between two or four switch LED’s ON
I think it’s because of the low voltage warning the main auxiliary leds can give that they are wired up directly to the battery. The side switch lights are wired to the mcu which has regulated voltage (regulated on the 2S and 4S drivers, I’m not sure about the 3v drivers).
If you don’t mind losing the low voltage warning, I believe you can wire the aux led board to the side switch lights in parallel. Then the 7 clicks will control them both. I think 2 of the 4 side switch lights are still wired direct. Those can be disconnected or wired in to the others.
I don’t think the MCU is regulated.
Here’s a previous comment by Toykeeper about making it so you can shut off the aux LED board and all 4 button LED’s:
http://budgetlightforum.com/comment/1413578#comment-1413578
iamlucky13
One possible option for turning off aux LED’s is a component called a bistable or latching reed switch. Some of those I’m finding spec sheets for are very small – about the size of a 1/4W resistor – but I’m not sure where to buy them.
It might be possible to wire one in series with the aux LED board, and if it can be located close to the lens, trigger it with a neodymium magnet.
Normal reed switches are momentary. Latching reed switches switch on or off depending on the direction of the magnetic field.
ToyKeeper
ToyKeeper's picture
Last seen: 3 hours 17 min ago
On Fireflies lights so far, the buttons have 4 LEDs:
  • 2 LEDs: always on, hardwired to power
  • 2 LEDs: wired to a MCU pin so the MCU can turn them on and off
… and the aux LED boards have more variety:
  • Always on, hardwired to power
  • Wired to a MCU pin so the MCU can turn them on and off
  • Wired to power and a MCU pin, so the MCU can tell it to turn on and off but it still gets power direct from the battery
The 2 controllable button LEDs could have low and high modes, but this option isn’t compiled into the firmware because Fireflies didn’t want it. It doesn’t really make much sense when the other 2 are always on.
The aux LED boards typically have potentiometers to manually adjust the brightness, and the adjustment range tends to go from ~200 uA to ~800 uA. However, the pots are physically inaccessible on some lights, like the PL47.
The aux LED boards also typically have their own built-in LVP:
  • Above ~3.3V: outer rings are lit up
  • ~3.0V to ~3.3V: inner ring it up
  • Below ~3.0V: aux LEDs off
Because of the way this LVP function is implemented, and the way it attempts to regulate aux LED brightness, the aux LED boards cannot do low and high modes controlled by the MCU.
There is no LVP on the 2 hardwired button LEDs. Also, there is not yet any LVP in Anduril while it’s asleep, so if voltage drops too far during standby it won’t respond until after the user wakes it up. But the aux LED board LVP is always active, which helps a lot since it draws about 98% of the power during standby.
gregor
gregor's picture
Last seen: 1 hour 58 min ago
I must say that I’m very disappointed with ROT66. If I bought it in local store, I will return it.
The problem is that returning FL to China is too expensive. So I’m stuck with this FL.
Can you calculate, measure how much power do all blue leds and swich leds consume together?
Thank you
Kind regarads
ToyKeeper
ToyKeeper's picture
gregor wrote:
I got ROT66 two days ago. It’s very nice flashlight.
I love it. Everything is working fine.
I only have one small problem. I don’t know how to turn off small blue leds and leds inside switch. They are always on.
It can be measured with a common DMM / multimeter.
However, that may not be necessary because measurements have already been posted. It should have a standby time of 1.5 years to 9 years with the aux LEDs on all the time, depending on how you configure them. It can also be turned off entirely by using physical lock-out.
Why does this change your evaluation from “I love it” to “I’m very disappointed and want to return it”? It seems like a large reaction to a small problem.
gregor
gregor's picture
I still love it but after I found out that small leds can not be turned OFF, I’m not so happy anymore.
This is my frist FL which has leds always ON and I don’t like this feature.
What is physical lock-out?
Can you please explain?
I now unwind tailcap to turn it OFF.
Thank you
Kind regards
Aleister
Aleister's picture
Last seen: 5 days 22 hours ago
Physical lockout is exactly what you do, physically open the circuit so no electronics are powered by the battery.
Let a flooder be my wife and a thrower be my mistress
gregor
gregor's picture
Ok, good to know. Big Smile
And if I understand correctly, internals can be rewired so that leds will not be on 24/7.
But for this procedure you must be expert in custom DIY projects. I never opened any FL.
Kind regards
joechina
Last seen: 3 days 20 min ago
Tom E wrote:
So for each of these 3 lights, 3 different AUX LED options, and on the ROT66, can’t turn them off at the head? Oh boy…
The Aux-LEDs on the ROT66 are an afterthought.
The D4S had it first and ROT66 was always out. Then Lexel designed an Ledboard based on a lit tailswitch.
Ryzbor
Ryzbor's picture
How do I access the highest regulated mode?
virence.com Nichia E21A sw30+sw40 Wizard Pro ; Skilhunt H03 XP-E2 660nm Photo Red ; Wizard Pro E21A 2000K ; S2+ E21A sw40 d220 (for sale)
iamlucky13
The simplest way is to set one of the ramp ceilings to it. For the 219B (7×7135) version, it is level 115. For the others (14×7135), it is level 125.
These are the default ramp ceilings the ROT66 ships with.
peg matite
peg matite's picture
Last seen: 18 hours 40 min ago
I don’t get all the angst about the aux LEDs draining the battery in these lights. Charge your batteries once a quarter and your flashlight is probably 3/4 full or so, no?
All I read is you shouldn’t just let batteries sit in there for months on end anyhow.
Not wanting them on “just because” – that I understand a little more. Mine is tucked away a bit so the “purple haze” causes no problems.
Or should have I posted in the unpopular opinion thread???
Tom E
Tom E's picture
Last seen: 8 hours 29 min ago
On my nightstand, the PL47 throws some decent amt of light when your eyes are fully adjusted to darkness, so I can see for that reason not to want the front AUX LED's on, but can always give it a twist. It would just be more practical for all if controlled from firmware.
ToyKeeper
ToyKeeper's picture
More like once every year or two. The standby runtime is measured in years, so a few months shouldn’t be an issue.
However, li-ion cells in general should be stored at roughly half full if they are to be unused for a long time. Leaving them fully charged or leaving them empty tends to decrease the capacity a lot faster than storing them half-full.
iamlucky13
I finally dialed the potentiometers on mine down to the minimum level last night. It was an easily noticeable decrease in brightness when I adjusted it, although they’re still brighter than I’d like for sitting on a nightstand.
Since I keep mine in a drawer, that’s not really a problem though.
JasonWW
JasonWW's picture
Last seen: 1 day 13 hours ago
There is no explaining people. We are all very complex. I would not waste time trying to understand it.
Personally, I always add directly powered auxiliary lights to my flashlights. I’m not bothered by parasitic drain because I simply turn the battery tube or tail cap or click the rear switch when I’m not using the light. If people think that’s too hard or too complicated, etc… thats on them. I don’t waste my time analyzing why they feel that way.
The overwhelming majority seem to like the aux lights. It’s like that saying “You can’t please all the people all the time”. Big Smile
Ryzbor
Ryzbor's picture
I asked Jack to send me the light with the aux leds turned off. Today I removed the optics and turned all the potentiometers a little but the aux won’t get one. Which of the three needs to be turned?
JasonWW
JasonWW's picture
About the only way to turn them off, as in no parasitic drain at all, is to not connect the wires. I would check that there is voltage going to the potentiometer. If so, then it should be simple to just turn all the pots until the leds start glowing.
Ryzbor
Ryzbor's picture
After turning they won’t turn on so I guess there is no voltage.
JasonWW
JasonWW's picture
You can check by probing here.
See the + and the ground goes to the screw/flashlight body. When powered you should be close to battery voltage, 3 or 4 volts. If no voltage, the wire to the aux board is not connected.
Ryzbor
Ryzbor's picture
Seems the wires are not connected. I asked Jack to turn them off not to disconnect totally rofl, lost in translation apparently and my fault for asking for changes.
contactcr
Last seen: 10 hours 6 min ago
Sounds like they did exactly what you asked to me.
JasonWW
JasonWW's picture
What are the smaller and different looking blue and green wires? They seem to be looped up there for no apparent reason. I wonder if one of them is the power that goes to the aux board?
ToyKeeper
ToyKeeper's picture
Yes, that is exactly what Ryzbor was showing. On request to turn off the aux LED board, Fireflies disconnected the aux LED board.
This was probably done because there is no other way to turn it off. Later models like the E07 switched to a 3-wire setup which allows the MCU to turn the board on and off, but on the ROT66, it’s wired directly to power.
JasonWW
JasonWW's picture
Can someone show a ROT66 with all 4 wires hooked up? I could not find any pictures.
shirnask
shirnask's picture
Last seen: 5 hours 12 min ago
JasonWW
JasonWW's picture
shirnask wrote:
Nice, now Ryzbor can connect them if he wants.
heatwaves
Last seen: 3 months 1 day ago
Would it be possible for one of you to post a graphic illustrating where the potentiometers are and how to adjust them? I’d love to be able to ramp mine up a bit. I love the aux leds.
JasonWW
JasonWW's picture
They are labeled POT_D1, POT_D2 and POT_LVP. There are 3 of them and they have the Philips head adjustor so you can turn them with a screwdriver. D1 looks to adjust the outer ring, D2 the middle ring and LVP adjusts the inner ring.
Look at the 1 o’clock, 2 o’clock + 7 o’clock position
heatwaves
Awesome! Thanks.
