Is it actually possible to order a GT mini without the bezel glued? I’m getting rather sick of manufacturers that work with BLF surprising us with glued parts on the production run. Enthusiast lights should never be glued.
Lumintop, you have a lot to answer for
What is that? Glue on the threads, crappy anodizing, crappy threads, or what??
That’s blue Loctite, which makes removing the bezel a huge pain in the ass.
OK…. That’s what I thought but could not tell for sure from the pic.
I just gave up on getting mine off… it was not worth the trouble to me.
I can’t understand why they would use that much…… that is total & complete overkill if they are going to use it.
If it is a BLF light I wish they would stop using any glue or LockTite at all.
Maybe if we start voting with our wallet, they will.
mine will be here tomorow unless the storm stops ups i am so excited
That’s normal.
Here’s my glued ODF30.
They said it was glued, so they have nothing to answer for.
Hello, I just purchased a GT Mini and will receive it today.
QUESTION: Are IMR 18650s or 18350s batteries okay to use in it?
thanks!
I have a Samsung INR18650 30Q in mine, and it works just fine. I would look for documentation saying it would be OK before using two 18350s, due to the higher voltage than two CR123s.
yes high drain 18650 recommended, and 18350 will work if using the shorter tube.
Mine was glued with a bunch of thread locker too. Two strap wrenches and the bezel was off in a minute. Used naptha to clean it up.
Thanks!!! Look forward to comparing the Mini to it's bigger brother )))
liteupmynite i think the bigger will eat up the smaller
Mine does this too. Sometimes have to click 3-5 times for it to turn off. Seems fine otherwise.
Unfortunately I don’t know where it’s from, picked it up on the Flashlight fanatics group on FB.
I’m having some problems. The switch behaves strangely sometimes. It started working fine a few days ago when I loosened bezel a tiny bit. I opened it again today removed the reflector to check something and put it back and it started doing random things again. Like not not detecting clicks and sometimes detecting two. It seems to fix itself sometimes but then starts malfunctioning again.
Many people have/had these switch problems on their GT mini, it sometimes fixes itself when you let light run very hot a few times (mine did) but some people have asked, and got, a new head for their GT mini because of the faulty switch.
Unless I missed someone, I count 19 people to date who have posted about switch problems. They are….
djozz// Reported RESOLVEDmortuus// RESOLVEDteacher// RESOLVEDRobertB// Reported RESOLVED
………gabo// RESOLVED- Cereal_killer /
Jhicks2018// RESOLVEDP33/ // RESOLVED (“partial refund” reported)- Coyotehawk
X3/ // RESOLVED (PayPal dispute refund)- illuminos
- Silent_Star /
Juheebus/ // RESOLVED (Replacement head)- mb200k
Pulstar// RESOLVEDA92AA0B03E/ // RESOLVED (Replacement head)komeko// RESOLVED <span class=“+ “HERE”:(prototype) the GT Mini - #1417 by komeko +explained refund… & dispute PayPal”>- Th558 /
- Icarus / //
Anyone else having any type GT Mini switch problems besides the people I mentioned above??
List updated. Icarus Added, 9 January 2019
Do the problems with the switches continue or have they been solved with the new models?
I think things have been resolved.
Thanks, I’m going to buy it now that it’s on sale ($ 29.90 with 18350 tube).
I got a new head (I think) from Neal. I said I think because I'm currently travelling until the end of March but I'm sure the package they showed me a picture of must be the new head from Neal. In other words all should be fine now but I'll report again after I'm home.
Big thanks to Neal anyway!
I just received mine from Banggood and have the switch problem, I’ll have to talk to them to see what solution they give me.
