K, thanks! I see a few 3 lead parts plus resistors feeding both wires going to the switch PCB (AUX LED's). Maybe the input from the MCU is going thru resistor(s) and acting as a pass-thru in the other components to one of those wires, not sure. My EE friend I guess is not fond of reverse engineering because if I ask him bout this stuff, he always asks me where's the schematic :FACEPALM:
What would be a good deal price for SP36? I want to buy one, but since I don’t really need it and I already have the Q8, I can wait for a discount to come along, just need to know what price to aim for.
Right now the lowest I can find is $52 on Aliexpress, and I can’t justify this price (Q8 is going for $46 on Banggood right now).
I think a deal of around 45 dollar should come along at some point. But when we discussed a possible group buy pricing some time ago (a group buy did not happen btw), Barry assured me that the SP36 is a more expensive flashlight than the Q8, so do not expect extremely low deals for it.
Curious, do you know what makes it more expensive? Is it just because of the USB charging circuitry? Or the new LEDs are more expensive?
It is mainly the USB charging feature I think. Looking at the circuit board (with my limited electronics knowledge) it is implemented in a proper way.
Another reason can be that the development costs have been higher than the Q8. All expertise that went into the Q8 came from BLF, while for adding USB-charging to the SP36 both hardware and software had to be newly developed by Sofirn.
Best deal is M4DM4X, cheaper than those prices. But BG just added another 4 weeks to the back order date! I got one on order and waited weeks for the Jan 28th stock, now pushed to Feb 24th ---
Best deal is M4DM4X at BG but no availability. Fortunately I got one in from Ali, ordered back in November, now running 4000K 351D's 90+ CRI.
Yeah, best price, but have to wait a moment 4 weeks min… I wait
Good news. My battery holder replacement just came today and it works just fine!! Thanks so much for @Sofirn for the help! Definitely one of the best in customer service!! definitely Will buy more lights from Sofirn from now on!!
Tested on my TA lumen tube and get 6000 lumens at turn on and 5400 at 30 sec. It gets very hot, super quick though
Ordered SP36 from Banggood today, will be interesting to compare it with BLF Q8.
It doesn’t have a coated glass, does it? I know Q8 has regular glass.
Not very sure if the glass lens on the SP36 is AR-coated or not.
The BLF Q8 glass doesn't shimmer purple/blue when reflecting off light, so it uses an ordinary non-AR-coated glass lens.
However, on closer inspection of the SP36 glass lens, I think it shimmers a very very light purple, so maybe it is very lightly AR-coated, if there's something like that..
This is my beamshot comparison of the SP36 vs the BLF Q8. (SP36 has the cooler tint)
Good news is BG shipped my SP36 Feb 1st - what happened to the 4 week delay,end of Feb shipping date, no idea.
Bad news is Martin's discount price went up a couple dollars, not sure why. Fin17's deal here is a little better now, which matches GearBest's limited qty discount offered here: https://budgetlightforum.com/t/-/28604/5420. All those prices though are/were within $2.
About the AR treatment - yes, I can confirm there's some sort of AR treatment on the SP36's lens - I can see a light purple, same as d_t_a noted above. Weird they don't list it in the specs though - you think they would want to.
My calibrated readings of the stock SP36 are very close to what Funtastic reported above (6,000/5,400), here's mine:
6,000 lumens at start, 5508 at 30 secs, using a set of VTC6 cells, solder blob tops.
The #'s improved slightly after upgrading the springs to the Blue Be/Cu large ones (~140 lumens).
My SP36 is now running with 351D 4000K 90+ CRI LED's doing 4,320/3,954 lumens (ANSI calibrated).
To be clear, my reading is for the SP36.
Can anyone give me an idea as to why my Sofirn Q8 doesn’t perform as high in lumen output to when first purchased? With a spring bypass I was getting 5000ish lumens at 30 sec and now it’s 4730. That’s after cleaning it with electrical cleaner which got it up from 4400.
I’ve rarely used it, mostly a few bursts of turbo now and then. Never got too hot. Is this normal even with light use?
Oopsie, typo of SP36 - got Q8 on the brain... Corrected my post.
The Sofirn Q8 is XPL HI's, so lower readings, but of course that doesn't explain why they would go lower over time. Maybe oxidation of the brass ring? Sanding smooth and treatment with NO-OX-ID should help keep it clean. I've found all those brass rings (Batt+ on the driver) are not flat as well. If you sand them on a flat surface, the ones I've done all show the outer edge is higher.
On the BLF Q8's I have seen lower readings if the batt tube was not tightened down. The contact of the battery tube to driver ground rings was not the greatest - some cases it barely touched the outer edge, and those are wear points. I'd check yours for wear, if you've been doing a lot of disconnects and tightens, like for lockouts, etc. You could add some solder there, sand it down flat, but it will also wear quick. Best would be soldering in brass maybe - doesn't wear as fast. Mechanical lockouts can really beat up the driver outer ground ring.
Also if the battery tube edge is rough, it's bad on the driver contact - I always sanded the top edge of the batt tubes smooth. I would think regular doses of NO-OX-ID on these contact surfaces should help reduce wear.
It’s lost that Loving feeling……… :cry:
My SP36 is now running with 351D 4000K 90+ CRI LED’s doing 4,320/3,954 lumens (ANSI calibrated).
That sounds like a really nice SP36.
It’s pretty decent in stock form, but the cool white emitters are still a bit of a downside. Something neutral with a consistent tint across the beam would be nicer.
Are there bare MCPCB’s available for the SP36? I’d love to keep the L2’s and be able to put some 3000K or 4000K XP-L HI in it if I wanted.
Thats only possible for the Q8 and C8F.
For the Q8 there are other footprints available.
https://de.aliexpress.com/wholesale?catId=0&initiative_id=SB_20190213110332&SearchText=sofirn+mcpcb
https://led4power.com/product/l4p-blf-q8-40405050-38mm-dtp-direct-thermal-path-copper-mcpcb/
Yep, I actually have 2 of those. Just hoping they will be available at some point. Guess I will just modify the one I have. more of a 3500K fella.
It was asked on page 3 about PWM. Any update on that? Is it a mechanical switch? Any parasitic drain?
