Grats! Hoping to do something with my D4.
Iâve ordered aux led boards from Lexel. Looking forward to installing them in my D4 lights when they arrive.
Hit a snag with Anduril flashing, but hope to have it ironed out and working soon.
:partying_face: :+1:
Nice work! what sort of control do you have over the Aux board? While I donât like some blinkies, I do find the bike light blinky very handy at times. I would go for that, candle and lightning.
You can activate and deactivate the aux LEDs and you can also set them to beacon mode. The beacon timing can be configured before compiling the firmware, as well as which blinky modes you want to have (and anything else actually :D)
Pöbel I assume you patched out the parts of the code for the blinkies that you dindât want. The strobes do not run at 100% power in Anduril am I right?
EDIT: I read the code briefly and indeed: ââ full FET strobe can be a bit much⊠use max regulated level instead,â (Anduril code)â ;_;
Some nice work on the D4 lights going on
Crosspost from the âwhat did you mod todayâ for future reference
Tailcap in the lathe â> 15mm hole â> glued magnet (15*3mm) â> strongest magnetic attachment in my collection
Have photo of inside the tail cap?
Much nicer than my magnet job
The inside looks stock, in fact the tail is 3mm thick so the magnet is flush to both sides (inside and outside).
Finally succeeded in flashing my Emisar D4 with Anduril tonight!!!
I then promptly configured the double-click shortcut from off to turn the light on at a lower setting (I did 51 clicks instead of the default 31). This is on my bare aluminum head / titanium body D4. I had previously installed a washer around the button making accidental activation unlikely, but now with Anduril installed even if by some chance the button does depress and ramps up it will stop before it burns a hole in my pocket.
I need to flash my other D4 lights the same way, but I think Iâll do that another night.
GREAT Job. I knew you could do it
Thanks.
Never was able to get Windows to allow AVRdude on my desktop. I installed it on my laptop and flashed from that. The instructions were about right, except that the first try AVRdude failed to find the hex file. It erased the ATiny, but couldnât find the new file to put in its place even though I had it inside the AVRdude install directory. Fortunately, a quick edit to the command line to include the full path to the hex file did the trick.
nice!
after everything is done the whole process feels so easy, but before it felt like an endless battle - at least that what it did for me
Anduril with its vast customization options is just a work of art.
Installed Lexelâs aux LED board in my D4 last night:
It was too bright for me. The blue LEDs seemed as bright as moonlight mode! I added a random resistor taken from an old driver to dim it down. This helped quite a bit.
Mods I am still contemplating for this light:
Iâll post this here too:
Very nice.
Yeah thatâs what I used for a lighted switch on the D4, two 1206 green LEDs & two resistors, quite a difficult job mucking about with trying to get the switch right.
If you could dremmel out space for the compnents that would prob be better but youâll have a lot of experimetation with this
I actually used copper tape with the SMDs & wires soldered on and some 12mm acrylic tube to give a lighted ring effect, lot of trial & error there.
That looks nice CRX. what did you use for the new switch boot? Is your modded D4âs switch still waterproof?
Yeah, I went through quite a few iterations of switch as can be seen in the OP
I wouldnât go swimming with it but waterproof enough.
The final version has the LEDs & switch under a thin clear silicone sheet and diffuser film with a section of 14mm carbon fibre tube pressed onto it/ into the switch well then a piece of 12mm acrylic tube glued into place as well, then the black kydex switch cover was siliconed to the clear silicone sheet just under flush with the top of the inserted tubes.
A LOT of playing around with that but it is really good having the lighted switch so worth it
Nice & grippy now.
That looks great!
