FREEME ✌ ASTROLUX FT03S SFH55 9300lm & FT03 SFT40 2200lm 1300m NarsilM v1.3 USB-C - ALIVE
I dont know if I already signed up, but if not, then im in
Interested
So thats confirmed it does 190kcd with the SST-40? Thats amazing!
Can someone smarter than me do the calculation to figure approximant throw with an SST-20 (cause that’s still my plan)?
+1 , iv got some SST20 waiting also :+1:
Product listed.
So we are close to get the code right ?
Does anyone know a good place to get 21700 to 26650 plastic adapter/sleeves?
Interested
Yes please. I am in for one.
Can anyone recommend suitable 26650 cells for this (will be my first 26650-powered flashlight)? The Shockli 26650 IMR 5500mAh seem to be highly rated, but their product page at Mountain Electronics lists the diamer as 26.7mm and states ‘These are a larger diameter than most 26650 cells! PLEASE CHECK MAXIMUM BATTERY DIAMETER OF YOUR DEVICE BEFORE PURCHASING!’ Don’t want to get them and then find they won’t fit…
@freeme are you able to confirm the internal diameter of the FT03?
I think you need to lower the output or increase resistance for SST20. For multi led lughts no problem because the battery sag helps them survive. But in a single led setup I killed 4-5 SST20 leds with fet driver.
Freeme if I’m in for 3 lights can I use thecoupon I get 3 times for 3 separate orders? That way every single light will be under vat price level. But 3 lights will go under customs and need to pay vat.
I missed this one.
Might be really interesting I’m IN :slight_smile:
Has anyone received a code yet?
Really wish the SST-40 had some warmer tints available.
Just poking around….the product is showing on Banggood…but it’s status as far as location/warehouse is “DESIGN”. So…appears to still be in initial stages…but getting close. Guessing codes won’t be available until it shows “CN” warehouse…or vice versa.
Their Chinese New Year holiday will start this weekend. Most likely have to wait till both BG and manufacturer resume work.
Banggood has a option for CW and NW but I thought the SST-40 was only available in 6500k?
Interested
maybe nw is xp-l2
If you check the datasheet they come in 4500k-10,000k. The limiting factor to us hobboests is what a retailer sells and only CW have been for sale up till now. Astrolux could have ordered a full reel at which point they could spec a tint bin of their choice.
So, we’re not getting an SST-20 for the light, huh?
Well that would’ve been nice for 1000m+ of throw.
