Just poking around….the product is showing on Banggood…but it’s status as far as location/warehouse is “DESIGN”. So…appears to still be in initial stages…but getting close. Guessing codes won’t be available until it shows “CN” warehouse…or vice versa.
If you check the datasheet they come in 4500k-10,000k. The limiting factor to us hobboests is what a retailer sells and only CW have been for sale up till now. Astrolux could have ordered a full reel at which point they could spec a tint bin of their choice.
Question for the under-educated;
How is Astrolux getting 2400 lumen from a SST40 emitter? How many amps/watts to the LED?
Has anyone seen CD numbers? Tested one of these?
1. They aren’t getting anywhere near 2400 lumens. Even when heavily overdriven, 2400 lumens is the best case scenario at turn on with a full very high drain cell, and without counting optical loss, and temperature increase of the LED.
2. Candela/throw numbers seems a bit high for a domed SST-40 light, even massively overdriven.
In Convoy L2 which has about 5mm smaller head:
SST-40 N4 BA 9.5A 2226 lumens 172400 cd 830,4 m
Maybe the cd reading can be real because of bigger head but the 2400 lumens not. Maybe 2100-2200. I used 18 AWG wires in that L2 and all springs bypassed.
