Yes, but I find that you quickly forget the 141 grams of net weight and 7000mAh exaggerated or imaginary (your choice), it is not so good weight/performance ratio, I find that the INR26650-55A from PLB (which reaches him easily 6000mAh of capacity whereas only 5500mAh are promised initially on the paper) has a much better weight/performance ratio, after that is just my personal opinion.
Yeah of course.
Still, if it was rated for 6000mAh instead of 7000mAh, it would be very good for a LiFePO4 cell.
Regular lithium-ion 26650s do have much higher energy density densities(135Wh/kg vs 210Wh/kg).
I do not care about specs or claims. I believe in actual unbiased tests. Considering that, this LiFePO4 cell is amazing. Each cell has its applications, yes the PLB INR26650-55A whatever is much more energy dense, Sanyo NCR18650GA, LG MJ1/M36 or Samsung 35E even more. What's the point?
If I were to choose a cell for an UPS or automotive application this one fits way better than li-ion. Or, for example, as a MagCharger battery swap (2S cells).
If you don't like dishonesty just be trustworthy no matter what. As I believe, it always ends up being beneficial.
In my language there's a proverb which says Las mentiras tienen las patas muy cortas, which literally translates into Lies have very short legs. I think the meaning can ;-) be understood.
Cheers ^:)
By the way, I remember having requested Henrik this review long ago (post #619 in Review request for HKJ [Rechargeable Batteries]). Please take a look at the specifications which are found in the sale advertisement I linked:
These figures certainly look more trustworthy than any VariCore or VBatty claims.
I am using 2 of these cells in a solar powered light to replace a lead-acid battery, and it works just fine.
(for about one month now, i hope they last longer than the lead-acid battery, that was only one year old and the capacity was only 150mAh instead of 4Ah)
The capacity test on my hobbycharger gave about 6500mAh, but my cheap hobbycharger is not professional measure equipment like HKJ is using.
To protect the cells for over voltage and under voltage i use this protection board: https://nl.aliexpress.com/item/2S-8A-Li-ion-7-4v-8-4V-18650-BMS-PCM-15A-Peak-current-battery/32800676048.html?spm=a2g0z.10010108.1000013.3.3e367ecfk06lou&pvid=fbbf3d65-a32c-4bf2-8991-8767aa669f45&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.90158.0&scm-url=1007.13339.90158.0&scm_id=1007.13339.90158.0
So, where did you get your cells?
I’d love to build a car starter with some of these cells.
Would be dope. Or maybe I should just be using LiFePO4 pouch cells instead for easier connections.
I don’t have any 32650 light but I imagine the diameter would be very comfortable to hold. Energy density doesn’t match the top cells (unless you limit your search to only match the chemistry), neither volumetric nor gravimetric but 150W/cell pulse with 90W/cell continuos is quite good. Would be a nice choice for some hot rod.
Given the discharge curves of this cell, it would require a buck/boost driver for proper emitter handling when 1S/1S cells/emitters.
Or 3s cell / 2s LED…High Vf LED. Nice 4.2V at 30A.
Driver development needs to step up further. If you keep thinking in plain MOSFET switches controlled with ATtiny microcontrollers this is unlikely to happen. Regulation is good, full regulation even better. Keep improving it.
I love regulation! I love FET based linear drivers for their low cost and high power density. I love induction based drivers for their efficiency.
But boosting at 50A input is expensive.
And a 32700 light won’t be superb in lm*h/g or lm*h/mm³. Therefore here I value efficiency less than elsewhere.
But I view these cells as a good match for big toilet plungers. Cheap, probably better grip than N*26650 and 4N*18650, powerful.
Rusty bottom means they are probably factory rejects.
The cells i got did not have rust, they were clean.
Rust in cells can form in humid saline environments, near cold shores for example. A friend of me took a few cells in a trip to the northern lands of Spain and they came home with some serious rust crust, particularly in the more frequently used units. We were cleaning and rewrapping them the other day.
On the other hand a bit of rust is probably no issue for chinese factory quality control departments, and certainly not for their wholesalers/storekeepers. And given my knowledge in this regard, neither is for me.
Kłamstwo ma krótkie nogi. In polish this proverb translates exactly the same. More common than I thought.
I’m surprised that there’s not much discussion about these cheap cells. I have ordered many batches from Aliexpress and Ebay from different manufacturers. I have not tested all of them yet, but here’s some initial results:
- Noname cells from Ebay: average capacity about 5800mAh
- Varicore brand cells from Aliexpress: average capacity about 5850mAh
- Liitokala brand cells from Aliexpress: only one tested so far. Capacity 6262mAh
All cells look pretty much the same, but Liitokala has slightly different looking positive pole. Capacity was tested by discharging to 2V using ZB2L3 module with 2 Ohm resistor.
For the price these cells perform great and have pretty consistent capacity. Liitokala might have little more capacity than others, but they cost slightly more. I’m really happy if these really last the 2000 cycles mentioned in the description.
Does anyone else have experience or measurements about these gray 32700 LiFePo4 cells?
Let me just bump this thread.
I want to buy 4 of these cells, but i would like to know who sells the best ones, or the best value for the price.
Many many AliExpress stores sell them, but even though they all have a gray wrapper, there are different specifications, prizes and even sizes (between 32600 and 32700).
Soooo…. Any advice is welcome.
(i want to use them in a MAGLITE 3D)
Jerommel, I usually keep track of stuff like this so, according to what I have, the shop where Henrik got the cells for his review (#1874160 LiitokalaVariCoreFlagshipStore) is where you should look at, section 32700.
Okay, thanks Barkuti.
