Just a quick gif to show something cool the button does…
(apologies for the large file size, slow loading, and shaky camera)
(edit: moved to imgur for faster downloads)
Thanks for this tip nvanlaar!
At Mountain Electronics there is an XP-L mod option that can be added when purchasing a Carclo 10507:
Anyone know what this option is about? Thanks.
It will make my day when you do! Take care, and Thanks!
@ ActiveAl…… He opens it up a bit to fit over XP-L emitters. This DOES NOT gave to be done for the XP-L HI.
Maybe sth from this thread HowTo: Modify Carclo Optics for XP-L Use--For $0.25
HD has a dome
HI is flat
Edit:
Massive advantage for drilling the optic. Cereal_killer explains it perfectly here: triple XP-L project, need your input. Problem solved?
That is neat!! Thanks for showing that TK……
there is an XP-L mod option that can be added when purchasing a Carclo 10507 … Anyone know what this option is about?
The original XP-L doesn’t quite fit into Carclo triple optics, because the dome is slightly too big. It’s a really close fit though, so the optic can be expanded a little to fit.
This is completely irrelevant for XP-L HI and LH351D though.
… and a few more pictures to show the size, color, and box:
Sizes and colors… The lights shown are, from left to right:
I’m also hoping there will be a diffuser cone made for it, because I like those and they work well with candle mode. I’m using a Fenix AOD-S now, but it’s not ideal. Here are a few of my lights with their party hats on:
Ideally, I’d like the FW3A diffuser to be nearly identical to the Olight S-Mini diffuser, except scaled up to fit.
One other nice thing about the FW3A is that it doesn’t cover any of the optic. Most Carclo triples obscure the outer edge of the optic, but the FW3A lets all the light through un-hindered:
… and just to keep all the pics in the same post, here’s that shiny button animation again:
Thanks for the pics & info TK. It looks as though most things are coming together fairly well…. hopefully that will continue.
Do I really need to insert the Futurama meme of Fry screaming “TAKE MY MONEY” ???
I think I just drooled on myself a little. It looks so nice! Thanks for keeping us updated. I really appreciate it.
In the OP it says “current status: anodization is dark gray”… now, I can’t speak for others of course, but to me dark gray would be something like graphite (or maybe a bit lighter than that) - in the pics it looks like it’s closer to silver, kinda like a middle gray actually lol.
Did you swap in clear optics btw? Or did yours not come with a frosted medium spot?
Have to admit, I actually prefer the dark grey.
Whatever color gray Proto 4 is, in TK’s picture above; looks just fine to me.
Both colors look good to me. What really has me excited is seeing it next to the SK-68, and realizing it uses an 18650. It almost seems like magic.
but which color will we get, the darker or the lighter one ?
Only time will tell for sure I suppose…… … When we open our boxes we will know with 100% accuracy.
We are getting the darker color. The lighter color (prototype 2) had issues with faint stripes being visable.
They changed to the darker color (prototype 4) and the stripes are gone. The new color is very consistent.
okay i see, i actually prefer the darker eventho it wouldnt matter which hey used . its crazy how small this light is, compared to that sk68 light more or less the same size i would never guessed this light uses 18650 if i didnt know about it before.
Darker, like Proto4; good!!
- Lumintop hasn’t received their order of XP-L HI 3D emitters yet, so they used extras they had in stock. On maukka’s, this meant ~5700K, maybe a 2B tint. On mine, it was ~4000K, like a 5A or 5D tint.
I’m not really a fan of warm tints, but this 5A/5D isn’t bad. I like it a lot more than the SST-20 4000K 95CRI light I had for a while, so I think I’ll leave it this way. The only nicer ~4000K tint I’ve seen was a Nichia 219B.
You are the luckiest receiver of all FW3A receivers! I wish that was the X-L HI version available on the production run.
4000K is my preference, and the 219B is still one of the top two nicest tints in that temp. The 219B is extremely consistent in my experience, and all the XPL-HI 4000K I’ve used have been slightly better or just slightly worse. The HI’s are really consistent for Cree’s.
