Fireflies E07 preview
I guess you guys would like the looks of the Amutorch X9 w/titanium tube, or the Amutorch AX3 head then - it's a dull/matte finish which to me looks cheap. I prefer the shiny titanium of the D4Ti tube, and shiny polished copper for flashlights. Even the SS bezels on the Amutorchs are a dull matte finish. I think the E07 clear ano version looks great as-is and doesn't look cheap at all, but when I think about it, for bathroom/kitchen fixtures I prefer the matte nickel or SS finishes vs. polished chrome.
What emitters and aux colors does it have?
I think the X9 bezel is titanium .
Well, for what it’s worth, the E07 isn’t polished Aluminum at all but merely anodized with no dye bath direct from the CNC machines. I love it, looks like I made it myself! (Yeah, right!) Does make me wish I had a mill though so I’d have the technical ability to make such as this if not the actual skill set… lol
As far as looking like a WalMart light goes, the only light I ever bought at WalMart is a MagLite and they have legendary ano skills so…. not sure why a WalMart light would have to look cheap by default. Buy dirt cheap, you get what you pay for…
Does the temperature protection only works at turbo mode?The light went dimmer(from turbo to ???) at 55°C.After that, it stays at the same level, so the light went very hot—->70°C
Is that normal?
Have you calibrated the ambient temperature setting in the light and also set the thermal step down? Relying on factory settings is not typically the way to go, they don’t set each and every light to work to your specs out of the box…
Calibrate the temp and set it lower. It works at any level above 380mah i think.
Yes, callibrated it with the temperature of the led board, step down at 55°C (25 clicks)
Yes, it's listed as titanium, so is the AX3 I have that has the same look to the bezel as the X9. But again it's the finish/look. The titanium tube on the D4Ti is more shiny, so probably personal preference what you like better.
I dropped the AX3 on my cold asphalt driver the other night and got a slight nick on the alum tail and also on the bezel. Least for the bezel, can probably sand it out, but the black anodized tail is not so easy unless I strip the ano off.
So I received my E07 today (SST20 95 CRI, clear anno) directly from Fireflies. The head was not glued, as ordered. The optic’s leg was broken off like most of the others - probably the old batch. Screws are intact though.
My Samsung 30Ts I ordered from NKON seperately fit in there pretty good - I don’t have a giant solder blob on the front spring like most people seem to have - looks decent.
I can see through the holes of the PCBs that mine too has no thermal paste whatsoever beneath it. However, from what I can see, the MCPCB sits flush on the shelf of mine, heat transfer is also immediate. I will open it to attempt the emitter swap anyway - then I will see more.
One thing I immediately noticed though is, that the battery tube has a slightly different gloss than the head and the tailcap - it’s glossier while the head and tailcap are more milky - are they made from different materials?
One very interesting thing: Fireflies claimed earlier, that the SST20 would turn blue immediately with a Samsunug 30T no matter how good the connection between the MCPCB and the light would be. This is not true for my light. Mines didn’t turn blue even when I kept it on turbo and it started regulating itself after some time (battery fully charged of course).
Another thing I have seen people mentioning only briefly: My E07 has the shittiest pocket clip I have ever seen. It’s so stiff that it just pops off when you try to open it enough to clip it onto your jeans - the clip’s connection to the light is just much weaker than the force needed to open it enough to fit any material in between. It’s completely unusable on mine.
Other than that - it works as far as I can see. Aux lights works, main lights work. The switch feels cheap and mushy but for me not as catastrophic as many people seem to think it is. After using it a couple of times it feels pretty natural.
By pocket clip, you mean the anti roll device? I've been flexing mine and got it opened up enough to work pretty well.The clip no longer is in contact with the tube.
On a 40T pulling over 23 amps initially, I didn't notice any blue as well on the SST-20 4000K's.
Let me know how it goes!
I would definitely like a nickel or titanium finish.
Emitters: XPL HI 4000K (barely used so far, since the battery I received it with is already in low voltage).
Auxiliary: purple and red for low voltage.
Actually I live in Europe, so Walmart is just a concept for me. I was just trying to express that this shiny silver metal does not work with me because it is too fancy and does not necessarily go with quality in my mind, and I prefer the (perhaps more sober) matte materials.
Personally, I love the look and feel of the shiny E07.
However, if you really find it too shiny and want to dull it down, there are better options than taking a scotch bright to it. It’s shiny because there is a layer of clear anodizing on it protecting the aluminum and preventing it from oxidizing.
If you want a duller appearance, just remove the anodizing. The simplest way is to soak the light in something that removes anodizing. I use Greased Lightning from my local hardware store. But you could use drain cleaner. Even bleach might work, but could take forever.
The safest way to do this is to disassemble the light and soak the bare aluminum parts. However, for this light disassembly is quite an operation and would require careful soldering. For those not comfortable attempting that, the next option is to soak the light whole.
Before soaking, I recommend checking and lubricating all o-rings. The light is going to be immersed in liquid for quite some time and you don’t want corrosive stuff leaking inside. You may also want to tape off the the bezel or other parts that you don’t want to become damaged. I’m not sure if Greased Lightning will affect steel, but I don’t think I’d want to risk it. I use vinyl electroplating tape for masking.
For safety, I recommend against soaking the light with the battery inside. If you need more weight to make the empty light sink into your soaking solution, fill the battery compartment with a stack of coins.
After the anodizing is removed the light will be a dull raw aluminum color. This will naturally oxidize to a slightly whiter color over time.
Anyone receive a colored anno unit with beveled fins yet?
I really love that gun gray, but also like the chamfered fins of the clear version.
Woo-hoo, DHL tracking FINALLY updated (this was the first actual scan and first actual log entry other than “awaiting item”) and my light is in Cali, should be here Tuesday!
Yeah… This style of pocket clip was going around a while ago, 2017 and 2018, from multiple brands. I’m not sure why that happened, but I don’t like it. Maybe it was a fad, maybe someone produced a huge amount and sold them cheap, I don’t know. I’d rather have almost any other style of clip though.
However, the rest of the E07 is quite nice. It’s definitely a light I make a point of using regularly, because I like it a lot.
I like this 2 way olight h2r clip better. Carry heads up or down option.
That’s a fair point, absolutely possible that fireflies didn’t know. But, for someone operating in this space acquiring tens of thousands of emitters and thousand of drivers and components, i consider it unlikely to not know who to trust to purchase a cell or how to tell the difference.
Regardless, we’re all rolling the dice each time we buy a budget light, and I wouldn’t have cared a single bit if this light was twice the price, I think it’s awesome. The battery deal, and then no official response or offer of making it right is shady.
Not sure what point of the clip design you are referring to - do you mean the click-onto-the-tube-style? Because the D4 has one of these too but it just works perfectly on mine. It’s much longer, weaker tension and just holds perfectly onto the body. I had it clipped onto my belt for months and I head zero issues with the clip failing. My Klarus XT2CR lost the clip about twice a day or so. Really annoying. The E07 now loses the clip whenever I try to put it onto ANY fabric. I could try to bend it, but i won’t wear as a pocket light anyway - the head is too big for my taste to do that.
The entire thing. I don’t like the one Hank originally used on the D4 either. And Lumintop tried to get us to use one on the FW3A at one point, but the team unanimously rejected the idea:
Here’s the one originally used on the D4:
… and on the V11R Mirage:
… and the E07:
I haven’t liked this clip design on any light I’ve ever encountered.
I’d like to see an Olight-style clip instead, ideally with a full ring (like the FW3A, and the SolarForce L2 clip) instead of arms.
