Material: Beryllium Copper C17530 38% IACS
Spring upper diameter: 4,25mm
Spring base diameter: 5,5mm
Spring thickness: 0,8mm
Spring height: 10,50mm
Total number of coils: 5
Plating: Silver electroplating
Same thing for the large spring:
Spring upper diameter: 5,0mm
Spring base diameter: 9mm
Spring thickness: 1,0mm Spring height: 12,00mm Total number of coils: 4/5
That last one is still problematic. We would lose the mechanical advantage of BeCu C17530 over higher conductivity. Stiffness was an actual advantage there.
Still, removing 1 coil from the large spring is still possible.
Is it to late to add more springs? I should be down for 30/ea already and thought the list was full. If we’re able to still add more LMK and I’ll get you an updated count.
Are we still able to add more springs? I should be down for 30/ea and thought the list was full. If we’re still able to add more LMK and I’ll get an updated total of what I want.
