I just bought mine with regular 70, OP reflr. I ordered the SMO separate. I have bunch of 70.2 laying around, will do the mods to emitter and driver. Need the the throw, but I do not like the darker yellowish tint.
I am partial to cool whites myself, but 5000k has a nicer blend on it. They are both P2 bin so if you have an inclining toward neutrals I would go with that.
Thanks for pointing that out. So not a good idea. What would be a good amperage to shoot for that leaves the 2 cell option open but gives the L2 some oomph. Also, are low and med. affected with this mod?
I like to run XPLHI at around 5 amps myself. You can go a bit higher, but it gets hard to sustain the higher output.
In TAs chart you can see he is getting some gains at 6 amps but basically nothing after that, and this is a control test, so if you drive the LED at 6 amps for 10 minutes you might actually have lower output than if you were at 5.5A for 10 minutes because of the heat.
I got my L6 with OP two days ago, just was ok, it did I think 3200L’s. I swapped out the OP for an SMO, ditched the 70 for 70.2. 65k, bypassed both spings with 20awg wires, change the power wires for 20awg, and just straight bypassed them BA sense r’s with braided wire. 6910 Lumens.
No stepdown, works very well and runs cooler on the handle than my Wowtac A4, MF04S modded, and blfgt70 after 2 mins on highest.
BTW, check your bargain L6, mine came from banggoods fp’d up at the head. 1. screw hole that holds down mcpcb, one was larger than the other and had no threading in it. It served no purpose. 2. Top of threads on the head was damaged, looked as though it fell at the factory on dull sword then banged on the assembly table to ovalize it for good measures to maybe prevent it from sealing out moisture just before they screwed on the lid.
Well I guess you mean stack like in iHop 3 pan cakes, lol.
Stack of 3 r100 would be .0033ohms or just .003ohms vs. 0 ohms, stock was .082x2= .04, correct me if I am wrong.
I was also pulling 11amps at the tail cap from two efest high drain and around 4.5 amps stock at the tail cap.
this should have been driven to more then 4300 only, why only so little? i think the host can easy handle 5000+ and more no ? looking mats video its only about a 500 difference in lumens vs the old xhp70 emitter.
I put the 0 ohm resistor, installed a 70.2 (4000K) in my older L6 and kept the OP reflector in it, amazing performance. Not sure if I am going to de-dome it because I like the beam profile as is. I may do all the mods to a different one.
I just got myself the L6 XHP70.2 and fitted two brand new Keeppower 5200mAh batteries. For some reason, the flashlight doesn’t light up at all.
Do you guys know if it could be the batteries, not having a high enough max continuous discharge? These batteries do work on the L2, so batteries are definitely ok.
What batteries do you use?
If these batteries should work, then there is a problem with the flashlight.
