I have never seen an SST-40 in anything other than a 6500K.
SST-40-WDS-F50-N4502 Luminus Devices | Mouser
SST-40-WDS-F50-N4502 Luminus Devices High Power LEDs - White White 5000 K 65-CRI, SST-40 Series datasheet, inventory & pricing.
Interested in special group buy price
Ok…all this “overstating” talk has me curious. I have an original run U-torch UT02, stock. Would it be safe to assume that the FT-03 will outperform it significantly? That’s my only goal. I’ll be honest, the UT02 does really well out to about 200 yards…maybe 250…but past that, it’s just “visible”.
I’m personally not going to concern myself too much if the FT03 can outperform that by a decent margin…for the price.
Any ideas?
Interested.
Interested
So what’s the code? I’ve not seen a code anywhere
Not available yet, probably next week or the week after.
Interested, please!
I would love to see more new pics or videos to keep the interest alive…
I’m interested in a few
Are the numbers on the Lumen and Lux accurate? Does it come with a battery or an 18650 adapter?
No tests yet, but:
Lux is close, lumens is 10-15% less, no battery, don’t know about adapter.
If you have a look on Banggood there’s no adapter advertised.
Any ideas?
The SST is going to outperform the UT02, yes. Bith the Lumintop ODL20C and Astrolux FT02 outperform the UTorch offering so this light should as well. It’s not out yet but I expect the numbers might be a little embellished but it’s likely to still be a remarkable light.
cdjaney:Ok…all this “overstating” talk has me curious. I have an original run U-torch UT02, stock. Would it be safe to assume that the FT-03 will outperform it significantly? That’s my only goal. I’ll be honest, the UT02 does really well out to about 200 yards…maybe 250…but past that, it’s just “visible”.
Any ideas?
That’s kinda what I was thinking. Thanks for the info!
SST40 in neutral white. Someone mentioned it in Kaidomain’s thread.
Nice find
Yeah it’s quite nice as I’ve actually found it.
The only problem is that the flux bin is N3 instead of the N4 used in djozz’s test, so lumen output will be even lower.
Edit: Sorry was wrong. Was thinking about N5 instead.
Isn’t the link for a N4? SST-40-WDS-F50-N4502
Interested as long as it stays under the $2_.00 mark.
