As long as it has auto off, beep for continuity and a bag/pouch of some kind to carry everything in, Iām not too picky. I have a VC97+. Two of them actually.
thanks for the good news BlueSword,
i check immediately
EDIT
yes, better price
ordered, many thanks for the suggestion
hi guys,
i am still waiting for the charger for the samsung batteryā¦ very long delivery timeā¦
in the meantime (and with delay, because i am out for vacancy) i have check the battery received from banggoodā¦ i do no see nothing of interest, all look goodā¦ BUTā¦ there is one cell that have a little swelling (i hope this is the right word)
looked whit eye is not visible, but when i touch the battery with my hand i feel the differenceā¦ i have grabbed a photos, i hope that the protuberance is visibleā¦
what you think? i have to contact banggood and ask for change the single cell? or itās normal?
if the multimeter (waiting for delivery) show good parameter for the cell, i am ok?
and last, seems that the IMALENT battery can be used inside the MF-01 (apparently the battery are the SAMSUNG re-wrapped)ā¦ also (and if i read/remember well) the MF-02 accept PROTECTED batteryā¦ itās correct?
and again, i read that i can made a light with two head: MF-01 and MF-02ā¦ itās possible? trow and flood at the same timeā¦
thanks to all.
@atomico, this is normal.
This is only the clear wrap around the battery which has not been installed well.
There is no concern over this.
many thanks
It is probably the seam of the clear heat shrink. You can probably tighten it up. Just use a heat gun or hair dryer.
Is there any working code now? After that time, any complains abput light?
good evening to all,
i read the review of the ASTROLUX MF-02 in this forumā¦ itās a very nice light and looks impressive for the throw distance (and price is very reasonable)
for what i read, the MF-02 seems to accept PROTECTED cells batteriesā¦ right?
i googled and find IMALENT 18650 are SAMSUNG 30Q rewrapped, this is a good choice i can imagineā¦
and now (yes, again) the question for the MF-01: looking the pictures of the MF-02 i see the battery holder is really similar to the MF-01ā¦ soā¦ i can use IMALENT cells???
yes, i ask previously for this, but itās sure that i can not use the protected cells? both have 15A of drainā¦ the problem is the protection circuit of the cell?
thanks guys for all suggestion and the BIG PATIENCEā¦
still waiting for the chargerā¦ damnā¦ very long time for deliveryā¦ i want to see these 12000 lumenā¦
Yes the Imalent MRB-186P30 do work in the MF01 like a charm. Theyāre actually the only protected cells Iāve found so far that do work. Not because of the rated amperes but because of their thickness. The MF01 has quite a narrow tube, so most protected cells wonāt work just because they physically donāt fit into the lampā¦
BTW, anyone had trouble with water proofness so far? Flooded mine today while holding it 5cm under the waterā¦ Those O-Rings seem so be quite minimal and the slightest dust or debris will allow them to flood Thankfully it was only the battery carrier getting wet and after drying everything worked againā¦
@seldor, I would advise putting silicone grease in the threads. This will help a lot, since you can make it airtight with it.
How much current does it take on turbo? Couldnāt find it fast in thread. I have beed trying light with Sanyo GA and Sony VTC5A and no noticable difference in beam.
This light uses a boost driver so the output should be regulated.
It will not go into Turbo once the battery voltage has dropped to a certain point.
The GA has more voltage sag under load compared to the VTC5A, so it will not have as much total Turbo run time. If you want the most total run time on Turbo, use unprotected high drain cells.
On Turbo, it can draw at least 8A per battery.
I know, I test many cells, 8 per cell, than it is 16A all current on turbo?
VTC5A are one one of strongest 18650, but GA have more capacity when on lower modes.
Because the batteries are 2S2P, if you use 4 batteries, it is 16A at 6v.
If you use 2 batteries it will try to draw 16A from each one.
If I use 2 batteries 2s1p it will still take 16A as it is overall current drain I assume? You make it less clear with this explanation. I asked if overall current drain is 16A? It is clear, that if you say 8A/cell than it should be 16A/2p.
I donāt know the specific design of this boost driver. Plus it went through at least one revision. Maukka tested an early version of it using 4 x 30Q fully charged and it drew 16A. He had to use a special test rig to get this measurement. This is why you donāt see anyone else measure it. I donāt even think anyone has tested the newer driver design. So I donāt have much info to go by.
Depending on how the Boost driver is designed, the amperage may go up as the voltage drops. So it could possibly draw 18A to 20A as the batteries drain (which would be 10A each battery).
I really donāt know what the amperage would be using 2 batteries only. It depends on the type of battery and itās state of charge. I will just say that each cell will draw at least 16A, assuming it turns on Turbo at all.
It is best to always use 4 cells in this light.
Use high drain for more total run time on Turbo.
Use high capacity for more run time at medium to low levels.
8A is a little bit too much for GA, but on the other side, it will go down before they get hot. I am not going to use 2 cells, only wanted to determine total current to know which cells are ok for this light. Maybe when I have some time I will check current on lipo or power supply. Anyone has idea of highest voltage driver can use?
I can only guess and say 8.4v to be on the safe side.
Keep in mind that using 8.4v from a power supply will not show an accurate amperage because a batteries voltage will sag under load. Maybe 7.8v will show a more accurate amperage (simulating 4 x 30Q under an 8A load per cell).
I would be curious if the amperage goes up as you lower the voltage. There is a chance the amperage will stay the same and the brightness will decrease instead.
Interested in Nichia
I just noticed that post #1 says input goes up to 9v.
At the same time, I notice Banggood says:
Uh, who knows. :weary:
If anyone ever sees this light sold as a host, let me know.
