Interested
SST-40-WDS-F50-N4502 Luminus Devices | Mouser
SST-40-WDS-F50-N4502 Luminus Devices High Power LEDs - White White 5000 K 65-CRI, SST-40 Series datasheet, inventory & pricing.
Interested
So what’s the code? I’ve not seen a code anywhere
Not available yet, probably next week or the week after.
Interested, please!
I would love to see more new pics or videos to keep the interest alive…
I’m interested in a few
Are the numbers on the Lumen and Lux accurate? Does it come with a battery or an 18650 adapter?
No tests yet, but:
Lux is close, lumens is 10-15% less, no battery, don’t know about adapter.
If you have a look on Banggood there’s no adapter advertised.
The SST is going to outperform the UT02, yes. Bith the Lumintop ODL20C and Astrolux FT02 outperform the UTorch offering so this light should as well. It’s not out yet but I expect the numbers might be a little embellished but it’s likely to still be a remarkable light.
That’s kinda what I was thinking. Thanks for the info!
SST40 in neutral white. Someone mentioned it in Kaidomain’s thread.
Nice find
Yeah it’s quite nice as I’ve actually found it.
The only problem is that the flux bin is N3 instead of the N4 used in djozz’s test, so lumen output will be even lower.
Edit: Sorry was wrong. Was thinking about N5 instead.
Isn’t the link for a N4? SST-40-WDS-F50-N4502
Interested as long as it stays under the $2_.00 mark.
I’m interested.
Interested
Interested
This should destroy the UT02. At least in lux. Reflector is going to be roughly 8mm larger.
