wstrachan
(wstrachan)
February 3, 2019, 8:51pm
372
cdjaney:
Ok…all this “overstating” talk has me curious. I have an original run U-torch UT02, stock. Would it be safe to assume that the FT-03 will outperform it significantly? That’s my only goal. I’ll be honest, the UT02 does really well out to about 200 yards…maybe 250…but past that, it’s just “visible”.
I’m personally not going to concern myself too much if the FT03 can outperform that by a decent margin…for the price.
Any ideas?
The SST is going to outperform the UT02, yes. Bith the Lumintop ODL20C and Astrolux FT02 outperform the UTorch offering so this light should as well. It’s not out yet but I expect the numbers might be a little embellished but it’s likely to still be a remarkable light.
cdjaney
(cdjaney)
February 3, 2019, 10:22pm
373
That’s kinda what I was thinking. Thanks for the info!
qjarq
(qjarq)
February 3, 2019, 11:46pm
374
SST40 in neutral white. Someone mentioned it in Kaidomain’s thread.
BlueSwordM
(BlueSwordM)
February 4, 2019, 1:54am
376
Yeah it’s quite nice as I’ve actually found it.
The only problem is that the flux bin is N3 instead of the N4 used in djozz’s test, so lumen output will be even lower.
Edit: Sorry was wrong. Was thinking about N5 instead.
AlexGT
(AlexGT)
February 4, 2019, 1:53am
377
Isn’t the link for a N4? SST-40-WDS-F50-N4502
blueb8llz
(blueb8llz)
February 4, 2019, 5:12am
378
Interested as long as it stays under the $2_.00 mark.
Redlyne22
(Redlyne22)
February 4, 2019, 9:26am
382
This should destroy the UT02. At least in lux. Reflector is going to be roughly 8mm larger.
mgracia85
(mgracia85)
February 4, 2019, 5:57pm
385
Is this gonna take a flat or button? or either?
Eleziel
(Eleziel)
February 4, 2019, 9:25pm
386
I’m going to guess official support for flat top and button tops will work as long as they aren’t too long (looking at the FT02)
Johm
(Johm)
February 4, 2019, 10:23pm
388
My guess is that even the longest 18650’s and 26650’s will fit since it also takes 21700.
I don’t know about ‘long’ 21700. (or how loose ‘short’ xx650’s will be)
AlexGT
(AlexGT)
February 5, 2019, 12:45am
390
Can we please have more pictures?
