No the Original turned the Opposite way, Right Hand Threads to tighten the Head and the Ring turned to the Right for more Brightness which was the opposite direction iirc?
MascaratumB
Thank You for the Heads Up.
This light looks like it’s a Larger Diameter than the old style. With the Ring turning the other direction I Don’t know if I could get use to that very easily? My Sunwayman Rotery Lights turn to the Right for More Lumens Like the Old style JetBeam. That would take some getting use too. But it still looks Good.
It is odd but true mate!! :weary: I tried it a lot of times and I couldn’t get the Aspire or the Keepower 750mAh to work on the old RRT01 I got from you :zipper_mouth_face:
It really has to do with this:
I believe that if I “shave” that plastic ring or if I put a small disc on the top of the batteries, it will work, but so far I couldn’t make them “light the light”!
I am using an OTR 16340 700mAh in it!
Sorry about that last post showing up So Late I previewed what I had typed then pressed Save, But apparently it didn’t post until Just Now?
The Light does look good and it’s Sure to have some Nice UpDated features.
the old RRT-01 and the new one are the same. The head screws on the same direction, and the dial increases brightness the same direction.
Yes if I turn the dial all the way up, it is possible to unscrew the head on an RRT-01, if it was not screwed down tight.
Yes when I turn the dial all the way down, that is the same direction that tightens the head.
It is not actually a problem. I just tighten the head, and use the dial normally.
the confusion is caused by the video that HK posted being reversed.
if you watch the video I reposted, after flipping it, (post #115) you will see that the head threads and dial turns are the same in the new model, as the old model.
The new RRT-01 showed up today. The operation direction is the same as the V11R, unscrews the same too. This one has 2 quick turns to the right and its in strobe that vary’s brightness. 3 quick turns to the right and its in sos. Simple UI. It also has detents all the way around. The detents at off and high are more resistive in motion. It’s kind of like a lock in off and high.
It experiences the same drift in the same manner as the V11R. First turn on lots of drift until warm, stable once it warms up. Turning the light once stable 360 degrees about the same as the V11R, I saw 10 to 12 lumen drift at the upper end.
In my lumen tube using a Aspire 18350 the highest I saw was about 800 lumens for just a second. Settles around 700 lumens and decreases slightly as the battery depletes.
TIP: Assuming the new RRT-01 is constructed the same way as the old one, it is critical to desolder the driver wires from the star and completely remove the driver from the head of the light before twisting the two halves of the ring apart to get to the magnetic ring. If you twist the two halves of the head apart around the ring with the driver installed you will torque the driver wires and break them.
did you just tell me that there are more than just the 2 detents at off and max, in the new RRT-01?
iow, similar to the Eye10? which btw also has the strobe…
I have an Eye10 and the detents do not produce consistent lumen levels at each notch…
now Im sad, and my wallet is happy
It doesn’t really stop at the detents, its just a small catch you can feel when you turn it. If you didn’t want any detents at all, besides off and high you could sand or file them out. Their pretty small little grooves, a small ball bearing rides in the curved grove with a spring behind the ball.
I didn’t measure it clemence but it’s definitely not 16mm. I’m guessing 14mm or smaller. I already modded the light with a LH351D 4000k 90 cri, turned up the current, and larger emitter wires, so its back together now.
Looked to me like it was about the same size MCPCB as the V11R, which is a 14mm.
The MCPCB has two holes that are only partial drilled so that the MCPCB holding screws are counter sunk. Changing the MCPCB would be challenging unless you didn’t use the screws and let the reflector apply pressure.
Its making 900 lumens now of high cri light.
Fairly easy to mod, toughest part is the same with the V11R, getting the head and control ring apart, blue loctite. Wasn’t to bad though.
It does have a lot of parts to keep up with.
I like the idea of the 8 indents as it would make it feel more mechanical, also holding it where you put it.
It would also be good for helping you to know approx runtimes for example, feeling 3 micro clicks might = 1.5 hours runtime, making it less guessing for runtime.
I like the heatsinking copper to brass to aluminum & SS for drop protection.
I took several pics while I had it apart, I’ll try to do a proper right up tomorrow. I really like the light, but I’m a control ring fanboy.
I always wanted the old RRT-01 but never got a chance to buy one, so when the new one came out, I had to have it.
Thank you Moderator007. I have one in route, should be here by the end of the week. Glad to see getting at the emitter isn’t a huge issue. Blue Loctite hasn’t stopped me in the past.
I have a LH351 in 5000K and a Luxeon V2 5000K. Haven’t decided which one it will get yet. I put a Luxeon in a V11R. Didn’t have a 13mm or similar board for it so I had to make a 10mm one work. Reckon I will just reuse the RRT’s board and do a reflow. I didn’t notice any CCT number in the spec of the new RRT. Can you make a guess at what it is in stock form?
I told you wrong Clemence, the V11R uses a 12mm MCPCB. The RRT-01 seemed about the same size.
I will try to take the bezel off tomorrow and check to be sure.
Sorry but I didn’t play with it but a few minutes until I started taking it apart. :person_facepalming:
Under UV the xpl hi is yellowish orange if that helps.
