I didn’t compare heat or amps or runtime, but when I compared tint of SST-20 4000K 95CRI to an XP-L HI 5A/5D, I found the XP-L HI made a much nicer-looking beam despite the lower CRI. SST-20 looked fine at high levels, but I don’t use high levels very much.
With an amc7135 chip like the D4 uses, the bottom half of the ramp stays in regulation longer with lower-Vf emitters. Basically, it stays in regulation as long as the battery voltage is higher than the emitter voltage. Then on a low battery, output falls much like it would with a direct-drive circuit. It’s a lot like a buck driver, except it burns off extra voltage instead of converting that to current.
Heat can definitely be a problem when burning off extra voltage like this, but the 7135 chips have their own thermal regulation built in. It typically works well as long as the voltage is within spec. It doesn’t work at 5V and above though, and the chips tend to die when used that way.
I stand corrected, I understand what Blue was saying now. But to poke at this a bit further, is the Vf at 0.35A really above 3V, and in the D4 now we are talking less than 0.1A per diode. I’m still thinking you are not staying in regulation on a rechargeable li-ion battery in a D4 before the voltage is so low it no longer safe to be operating. Guess it is time to investigate the Vf for an XPL-HI led.
Thanks, looks like roughly 2.74V of diode voltage for more than 0.1A of current (as the 0.35A gets split to 4 LEDs), and supposedly 0.12V across the 7135, so the light will regulate down to 3V easily at the full 0.35A going through 4 diodes. BlueSwordM is correct, but I’m guessing most of us are not planning on using batteries at less than 3V consistently.
Does it take a week to ship? I ordered a D4 last friday, and 7 days later the status is still “processing”. It is in stock, so is it normal or should I start to worry?
Hm… Iam near to order this light with xpl leds… They dropped the price again or is it the old dropped price? The xpl version owners-whats the runtime on turbo? I got the samsungs, so probably cant get more from any othet 18650…
Runtime on turbo depends mostly on the battery you use, and the level you set the thermal limit to. That’s just how direct-drive modes work; the battery’s type and condition are a huge factor. However, in most cases, it’ll still typically be under 30 seconds before the first step-down.
30 seconds to first step-down? Unequivocally? So a week (or so) ago, in the Northeast US, at –35ºF ambient and with a strong wind, the light would still step down in 30 seconds?
Oh, I’m very well familiar with where the limits are… was just saying that there are variables, that’s all. Basically pulling TK’s chain as it were. lol Different ambient temperatures, different humidity levels, different wind levels, a different grip on the light… a lot of things come into play as to just exactly how long Turbo will go before stepping down if it steps down at all. She’s right though, of course, in most cases it steps down pretty quickly…
My D4 Titanium is in short body form, with an Aspire 18350 and Samsung LH351D 80 CRI 5000K emitters. I KNOW it’s going to heat up fast in Turbo, so I don’t use Turbo much at all. I have bigger more powerful lights if I think that level of output is going to be needed. I also have Anduril flashed so I can limit the ramp ceiling to a reasonable level without having to think about it in use. A double click changes everything of course, whole new ball game….
Edit: As an aside, my green D4 is also in short body format, with green output XP-E2 emitters. I had thought that these emitters would not pull enough to heat up strongly but boy was I wrong! Tint shifts very noticeably on the green output and heat comes in hard and fast in Turbo so again, I have Anduril ramp ceiling set relatively low and just seldom double click into Turbo.
