Tom_E
(Tom E)
February 6, 2019, 6:20pm
316
- all good bout the LED's
- No, I don't have a temp controlled hotplate - might have to investigate getting one. I used the hot air from under the MCPCB, usually works. For driver/PCB reflows, I use a coffee mug warmer - works well, an EE friend actually gave it to me because he no longer uses it, but uses a temp controlled skillet or hotplate himself, mainly to handle bigger boards, etc.
For the coffer mug warmer, I turn it on and let it warm up a big, set the board on it and you can see the solder paste already melting, spreading, then use my hot air station at a more reasonable temp from the top while the board sits on the mug warmer.
Any recommendations and/or links appreciated for a hotplate - I'll search BLF now...
hodor
(hodor)
February 6, 2019, 6:25pm
317
@BlueSwordM Just checking if you got my pm?
Tom_E
(Tom E)
February 6, 2019, 6:29pm
318
Ok, this looks bout perfect maybe: https://www.amazon.com/dp/B07456SPMF/ref=psdc_13838451_t1_B01LE0PD5Q?th=1
Reasonably priced, good rating, says it's a consistent heat - no cold spots, etc.
BlueSwordM
(BlueSwordM)
February 6, 2019, 6:33pm
319
@hodor , I’ll remove you, don’t worry.
@TomE , here’s a pic of the hotplate I use.
hodor
(hodor)
February 6, 2019, 6:35pm
320
BlueSwordM:
Thanks. That hotplate’s seen some action.
BlueSwordM
(BlueSwordM)
February 6, 2019, 6:40pm
321
Yep. That’s a relatively recent botch on my part though.
The light brown/orange stuff was some flux from experimentation trying to solder my springs with a hotplate. Ended up buying a heatgun after that.
The dark brown stuff is metallic copper sludge remnants(Cu3+), an oxide. I literally can’t remove it…
BlueSwordM
(BlueSwordM)
February 6, 2019, 6:46pm
322
Rusty
(Rusty)
February 6, 2019, 6:59pm
323
BlueSwordM: Please could you add 10no SST-20 4k & 10no LH351D 4k, in addition to the springs on line 19 of the s/sheet?
BlueSwordM
(BlueSwordM)
February 6, 2019, 7:01pm
324
Tom_E
(Tom E)
February 6, 2019, 7:03pm
325
Hhhmm. Guess the 100x100 size would be good enough to do least a few 17 mm drivers at a time, and can handle the biggest drivers or MCPCB's. The shipping cost is big though. I like they can go up to 200C, better than 212F (100C) max of the burners.
Unloco
(Unloco)
February 7, 2019, 12:06am
326
Tom_E
(Tom E)
February 7, 2019, 12:48am
327
Good price w/shipping, not much info on it - do you know the max temp? Hoping for 200C or better.
Found other listings that say 50-350 or 50-400 -- that's good, assuming in C!
Unloco
(Unloco)
February 7, 2019, 4:59pm
328
I have used it at around 200-220C but I think the max temp is 400C.
In a few hours, when I return to my home I check it.
djozz
(djozz)
February 7, 2019, 5:17pm
329
So how do you like that hotplate? It looks very small and convenient, I almost bought one. What time does it take to reach the set temperature?
AEDe
(AEDe)
February 7, 2019, 6:53pm
330
@BlueSwordM , could you please reduce my query to 10 * SST20 4000/3000 (springs and 3500 K are without change)?
Unloco
(Unloco)
February 7, 2019, 7:57pm
331
Confirmed. Maximum 400C.
I like very much. Since I have it, I have not failed any led reflow.
Room temperature 27C (air conditioned).
Hotplate initial temperature 33C.
Delay until reaching the set temperature (218C) 10:44 minutes.
shirnask
(shirnask)
February 7, 2019, 8:07pm
332
Unloco:
Thanks, I have been thinking about this unit for several months, you just convinced me - ordered
Tom_E
(Tom E)
February 7, 2019, 8:17pm
333
It's the best price as well on Ali. Others may list it cheaper but charge almost as much for shipping.
BlueSwordM
(BlueSwordM)
February 8, 2019, 2:01am
335
BTW guys, I’m going to order the 3000k LEDs at the same time as the springs.
Who would like additional 3000k LEDs?
If I could actually order 250 LEDs, I could actually make them a bit cheaper than 1,50$USD/pcs.
I’m also still looking at the SST-20 4000k.
