That Acebeam X65 doesn't make sense - 12K lumens is not right from qty 5 of those LED's - should be more like 10K lumens. The 423 kcd rated throw sounds low to me, considering head width of 108 mm and high amps to the XHP 35 HI's. Wonder if anyone reviewed/tested this light?
I modded a BOSS1 (100 mm head diam) with direct wiring, dedomed XPL, and got over 700 kcd.
Also I've gotten over 500 kcd on modded Shockers, a 106 mm head diam, 3 C8 size reflectors, dedomed XM-L2's.
Maukka tested one on BLF, but that was before he got his Lisun sphere and fancier equipment. With an older sphere and no calibrated light it was about 11k lumen at turn on and 10,500 at 30 seconds. I just asked him if he ever retested it using his newer equipment.
IDK. It’s good when the forum has some input on the design. It can help prevent them from making simple mistakes.
Luckily, this is a modified version of a well established light and I think Texas_Ace also chipped in on the design so it’s probably not suffering from any mistakes.
Hopefully they will swap to white centering rings for production.
I don’t recall seeing anything bad about the R90C either. I own one and it’s awesome, puts a huge smile on faces every time I show it off, and it’s got the lantern and green batt lights. It’s on sale on BG for like 229 right now. I don’t see the GT4 touching it on price or performance.
Yes, the R90C will put a lot of pressure on this light now. This light made more sense back when I first had the idea 2 years ago. Then it would of been the only real light in the class.
On the plus side it should put some pressure on lumintop to get the prices down as low as possible. There are a few possibly options that could reduce the cost significantly, but still way too early to guess at the final price.
