It sure is… Until the MCPCBs arrive and I can solder the LEDs, I mocked up one of the 9V solutions, the 400mA Cree LED driven at 500mA, so that’s a few more lumens than the nominal 366. The heat sink is too large, but I had no matching one around; 41°C is ok here. It’ll be interesting to see how long this lantern setup emits without dimming…
Edit 1: Finally reached steady 51°C after two hours
Edit 2: Now, after 7 hours, the output appears dimmed. Although the Cree used here is 3000K and CRI 90, there is a bit of a cool tint to it, probably because it’s driven at 500mA instead of the nominal 400mA
Yeah Stupid Imgur . I was having quite a problem posting pics for awhile . Their help thing didn’t help me too well. Here’s my idea . I’m gonna use an old glass & brass door knob . I’ve drilled the brass part to the glass . I keep going back and forth on the tube diameter. This is the largest diameter I think will look good . I have a convoy triple inside the tube just to light the glass so you can see what it’s supposed to look like.
Your image is embedded like this img src=“https://i.imgur.com/hS23jGZ.jpg” style=“height:200px; width:300px;” alt=“” so it looks like it’s that “i” from an imgur shared link that does the trick.
Yes, it really is. I will use the same model, but half the height is sufficient.
Wired up the Citizen LED 9V version using a CCS with built in dimming via momentary switch. It also works with a potentiometer. Although it is a 3000K CRI 90 LED like the Cree before, the visual quality of the light is more pleasant. Will be interesting to see how long this one will illuminate at 100% and 50% setting. It’s rated for 505 lumens (the Cree was 366).
Can’t wait for the Cree XP-L and the MCPCB to arrive from the U.S.; the 3.7V battery is so much smaller (but only half capacity).
After Euroluce Milan, Citizen should have the new CRI 97 Natural COB series commercially available. I hope there’s also a 9V version available, would be great for 2700K lanterns.
The problem with lanterns and all LED lighting is the balance of illumination strength vs. illumination duration vs. illumination diffusion. The Citizen above has been good for 9 hours at the medium setting so far. Have to try out full setting at 500lm, better for a small terrace or garden setting; maybe even sufficient for a caravan?
A sheet of Covestro Makrofol® LM 309 held at around 50mm distance to the LED. Transmission 81. Half-value angle 28°. Thickness 500µm. This special LED diffusor film is used in the automotive and aircraft industry. Looks ok considering the size of the COB. Have to try 300µm at a slightly larger distance, spec sheet says 85 at that thickness, but only 21° half-value angle. Well, I can’t have everything. The magic full diffusor with 100% transmission has to be invented still ; )
This stuff can be rolled into a tube of 40mm Ø before it cracks; the problem there is the seam, so vacuum-forming would be better.
If one of you fellow lanternists knows a material with higher transmission at around the same half-value angle, even if I have to get it from the U.S., please link to it here; I’d really appreciate that!
Edit 1: Rolled into a tube, quite sweet…
Edit 2: Turned it off after 24 hours at the medium setting with around 300 of the full 500 lumens. Enough for a good lantern, but 2700K version might be better still. On full setting now…
Do you have a source for small amounts of Covestro Makrofol, I can’t locate one.
If money was no object I would enjoy buying this sample kit of different diffuser films from Corbell Plastics. Different thickness, color temp and textures. Looks very fun to play with.
I got many samples from this source (use Bing translator), in the framework of a product development research project.
But I saw Corbell also trades in these wares, so maybe you can obtain single sheets from them?
Evonik USA also sells thicker similar materials and a flavor of Plexiglas that transmits the light at a 90° angle when fed into the edge of a block, rod or sheet, which is great for use in luminaires, quite unlike the classic edge-lighting plastics that primarily transport the light.
While waiting for the parts for the 3V Cree variant, and the two 9V versions working very well, particularly with over 12 hours on full setting, I thought why not go one step further and make these solar powered, so that the battery is charged during daytime and the LED comes on at dusk and then illuminates for as long as the battery can power it.
There is a timer breakout-board at Adafruit that lets one add low-power/timed-use to a circuit quite easily.
Existing balcony/terrace/garden solar lanterns look awful, their light output is visually garish and too low. Would be great to see more solar powered lanterns here!
Hey BraLjus , there are some threads on here on lantern talk . One is the BLF ultimate lantern project , by DBSAR . He is pretty knowledgeable about lanterns . It’s a long thread , but you may get a feel for some members or ideas that can help .
That Coventry sheet is pretty cool . I had never seen that before .
BLF Ultimate Lantern Project*~updates:Sofirn working on design, to produce prototype!
Yeah, that’s the only high transmission high half-value angle diffusor material on the market that works. I saw it at the Light + Building and Euroluce fair several years ago. Engineering these plastics is an art. Good to see that it is also available in the U.S. I’m always puzzled how some put a high-lumen LED in a luminaire - only to then kill 50% of the photons by using matt opalescent glass or frosted Polycarbonate or worse.
I clicked around in that lantern thread for a bit, it’s uuultra long, but I happened to come across an image and that looked rather as if a Kenwood blender had gone to bed with an SWAT-issue flashlight ; )
It’s a matter of taste and, as Oscar Wilde said, taste is a matter of taste : )
PS: Instead of a flat bottom, bouncing light right back onto the LED and surrounding heat-sink area, I would have made the internal reflector conical/hyperbolic/asymptotic… just like in good omnidirectional loudspeakers.
Expounding on my idea a bit, throw one of these into the body with its own on/off switch (to avoid parasitic drain) :
Then you could measure charging / discharging currents and have some idea of the state of the battery charge.
If you were car camping at night, and the battery circuit dipped below 12V, you could plug it into the car’s cigarette lighter, and the car’s battery would run the light and charge its batteries (assuming car battery had voltage >12.0V).
Thanks, Barry, I already bought 6V solar panels, chargers, batteries and 3V LEDs with matching MCPCBs (see first post).
The Cree XPLAWT-00-0000-000UU30E7, 3000K, 320lm, CRI 90, Vtyp: 2,95V DC, Ityp: 1050mA is just at the sweet spot for a single LED 3V lantern.
If USPS weren’t so slow, I would have tested that set-up already and posted some pictures and running times : (
Edit 1: That looks like a practical little meter… The idea expanding the lantern to solar would mean to use the solar panel itself as the darkness trigger, meaning that once the solar panel delivers 0V, a MOSFET switches the charger/battery <-> LED driver path on.
What do you think about, as a next project, a 4S LiFePo4 12V setup with on-board voltmeter/ammeter and 12V jack to connect solar panel or cigarette lighter lead?
And if you want it to be really boss , have it accept:
(Enough juice to start your car with appropriate cabling)
Once the pan is hot enough, you just drop in one MCPCB in after the other : )
With over 12 hours full lumens from the 11.1V set-up, it’s now going to be interesting to see what the 3.7V setup with the flat 4500mAh Li-Po battery will yield, and how the Cree’s CRI of 95 will make a difference.
