Dang Blue! I finished a ROT66 LED swap to your 3500K's from the 219B's and am very happy with it. Kcd is up 50% and got a slight bump in lumens as well, and really like the tint! Side by side with an E07 with their SST-20 4000K's and it's quite a difference - the 3500K's got that rosy touch while the 4000K's seam to have an something like an aqua blue. I thought the E07 looked really good before this side by side comparison.
Thanks Again!!
Other notes: swapped the stock teflon short LED wires with silicone 18 AWG longer ones to allow re-programming, and removed the inner spring of the driver spring and added in a short 22 AWG bypass. I left the dual springs in the carrier as-is for now.
I used the last 4 of my 3500k leds tonight. Installed them in a triple, accidentally busted one of them. The tint is very nice… Thanks for making these available.
I do not have the proper equipment for reflowing electronics, and so I was using the stove set to a low setting. I usually have no trouble doing single led boards, but multiple led boards give me more trouble. That combined with being a bit impatient while trying to clean excess solder from around the LEDs, and I just clipped the corner off one…
Getting a hot air gun or a regulated hotplate is on my long term wishlist…
Do you like your hotplate setup? What is it? I seriously need to figure something out sometime in the future…
I really like the jaxman e2l as a host, and it requires very delicately reducing a 20mm triple board down to about 18mm without shorting the + or - to ground. Its a pain but I enjoy the end product. (and mostly enjoy doing the work too)
Ohh, I did end up ordering the one Unloco linked: https://www.aliexpress.com/item/UYUE-946-1010-LED. It's the best price on Ali for this model. Talked to my EE friend at work and he thought it was a good deal as well. Thanks everyone!
