Nope that is USD. But, it is only semi production….the blades are hand ground. The handles and hardware are production. So the important part of the knife is custom…
I have a few that are high cost, and with a couple exceptions, I carry them. They don’t get heavy use, if I carry something expensive I usually carry a small fixed blade or a slip joint if something so that if something is really dirty or needs more abuse than I want to give to a $700 knife, I can use one of them.
I am not a fan of damask, as i see it there are not really any practical gains for doing that, so as a hard core Dane that kind of clash with our design philosophy.
I also spoke to a Danish knife maker ( no not one of the flashy ones ) and he laughed his ass off and said O hell no to damask.
BTW a few days during digging to make / fix sewers a nice sword from the 1300 or so was found.
The 93 CM ( 112 CM OA ) dual edge blade are still sharp they say, though i would like to feel that before believing it
Unfortunately we lost the knowledge of making real Damascus steel (Wootz steel). It was apparently a super steel, maybe even better than current steel. This may explain the legends about magical swords.
The current Damascus pattern is primarily for the look but still have interesting mechanical advantages.
It is true that damascus has no physical benefits, in fact it has some drawbacks, and is purely aesthetic. However, a company like Damasteel makes a very good steel for knife use being made of 2 modern steels that both have fairly good edge retention. One being RWL-34 which is more or less the same as CPM-154 and the second being an equivalent to 12C27.
It is actually a pattern welded steel, not technically damascus, which is a traditional steel making method that the Nordic people have been using for centuries.
That is just getting started. 20,000 to 50,000 is expensive. LOL.
I beat my 500 to 1000 dollar knives but Busse Combat knives are made for it as are Hinderers, for folders. Chris Reeve knives just can’t handle that abuse though. I was a Chris Reeve dealer so I know.
You can get a harder edge sandwiched between softer steel. This results in better edge retention with less chance of snapping the blade under hard use.
The hard edge between softer steel is often referred to as “san mai” and definitely works. My Japanese kitchen knives can attest to that. Spyderco and Falkniven have released several models with this method of construction in their blades. Some older axes are set up this way too.
I’m not certain that damascus works quite the same way with all the tiny layers though. I’d be interested to find out.
