Correct… but the emitter is not a small compared to the dome - in fact it’s roughly the same size as the dome, just a tad smaller. Because the bottom of the dome is flat - coplanar to the emitter - the light at each point on the surface will travel up first, then reflect off the so-called collar. But it may not necessarily reflect back onto the emitter. That is the reason for the air space in a TIR - to redirect the light as it hits the inner surface of the TIR. For this to work, you’d have to make the painted area a shape such that light hitting that painted area gets reflected toward the center of the LED that it can escape out of the unpainted area - would probably look like an axicon with a slight convex surface. I think with a dome, you will get more a TIR effect as you go along the edge, since the light will be hitting the edge of the dome at such a shallow angle.
I think I understand what do you mean - a photon is emitted on the side of the die. Then hits the collar. Then is reflected. Since it was off edge, it hits the die off another edge. When it’s re-emitted off edge AND is reemitted towards the open part of silicone - the chances of it reflecting off the silicone-air boundary are high.
If we managed to reflect it towards the centre of the die - it would have higher chances of escaping.
Yes, I think that near edge parts of the die have dead emission angles - where light TIRs off the air-silicone surface. I think that flat (or dedomed) emitters have these areas larger.
Yes, if we could redirect light towards the centre it would be better. Though it would also increase light loss at an earlier stage - light that bounces off collar but fails to hit the die.
I think that the optimal shape that maximises chances that a photon bounced off a collar would be near spherical.
I think that the optimal shape that maximises chances that a photon bounced off a collar eventually escapes the package is different. More light hits the collar from the closer end than from a farther therefore a flatter shape would probably be better.
Much flatter? I don’t know but I have a hunch that it’s not.
Anyway - we already have domes that are spherical or close to spherical. I believe their shape is imperfect but nevertheless good. I’m more worried about paints not sticking to the silicone or not surviving the heat….
Another idea would be to get a semi-hemispherical glass lens, coat the outer surface, and adhere it to an undomed emitter using a high-grade silicone.
But here’s the rub with the dome on the emitter as it is. If you paint the reflective area very low, the reflection line perpendicular to the tangent of where the reflection line meets the dome has such a shallow angle in relation to the LED surface than reflected light would mostly go across… where it may hit the dome on the other side, hit or miss the emitting surface depending on its location.
If you look at the de-doming work of ZozzV6, you see that after he trims the excess silicone (and therefore phosphor) from the sides, he essentially eliminates stray light going off to the side. So if you sliced the sides of the dome perpendicular to the edges of the emitting area, while leaving the rest of the dome intact, you should effect the result you describe without having to coat the silicone. I actually had thought of doing this, but the thought of potentially bricking an $18 XHP70.2 on DTP MCPCB has prevented me from trying. I may have some cheaper LEDs around to experiment with; have to look.
Interesting idea with the glass dome. And it may actually increase light extraction - glass has lower refractive index than silicone so sum of reflections on silicone/glass and glass/air interface will be lower than silicone/air alone. However you add another silicone layer. If it has higher index than the one that covers the LED you may negate that improvement.
Now that I think about it - it seems to me that high extraction coupled with collar would work better than low extraction of flat emitters.
So if one wants to use a domed emitter and a good collar - dedoming might be counter-productive. Not sure though…
When it comes to light hitting very low….there’s so little of it that it’s not a big deal really.
That’s why I think that a painted collar has a chance of being worthwhile when you can’t slice very low. Like SST-20. Or SST-40.
And for those of us who are not masterful enough to do this:
The promise of a painting a collar on the LED dome is low cost and simplicity.
Prepare a shim to make a slice.
Paint the dome, wait for it to dry.
Slice.
Thanks. I have backupped all my flickr images at home too, but for them to re-appear I would have to fix all the hyperlinks in all my old threads which will not happen. But I may fix some of them, perhaps the ones that are linked to in my “djozz tests” thread.
But for the time being flickr did not remove the 2700 images of mine that are at threat, although they warned that from Feb6 on that could happen.
Argo, please excuse this slightly off Topic post, but your title caught my attention and I figured perhaps it was something related enough to be of some interest.
I experimented with this principle of corralling off-angle/side-angle light to a different situation - green tint-shift.
I observed that a fair amount of tint-shift results from stray light from the sides of prone emitters. In my experiments, I placed “Magenta Collars” around the perimeter of emitters in an effort to filter out green, with some success.
Some of my earlier experiments that were successful, ultimately failed but did put me on my current track.
Here is an example of what I earlier called a “Magenta Collar” attached around the cavity of a LED spacer -
It would be placed inside a light such as this -
Notice the tint affecting primarily the side off-angle which appears at center of the reflector -
And here are the results of original beam (on left) and beam after a Magenta Collar (on right)-
The same light, with the same emitter, taken at the same exposure and white balance, with the only difference being the Magenta Collar! The green is reduced without dramatically tinting the rest of the beam as a lens tint filter might.
I mentioned that my experiment with the Magenta Collar failed, that was primarily because the plastic melted from the high heat of the LED. I suppose a collar made of higher heat capable material could be done but I’ll leave that for others to pursue.
It was my latest approarch, similar to your post (and as it turns out djozz’s) of a directly painted/tinted collar where I’ve settled for now. Here for example is an XP-G3 (notorious for green tint-shift) where I magenta tinted directly on the base/bottom perimeter edge of the led itself. It was equally as effective in reducing green tint-shift in the beam. This approach was also less construction dependent. (Sorry no before/after photos for comparison as removing the tint from the emitter dome is more involved than simply removing a physical Magenta Collar from a spacer.)
This magenta collar approach could be something for fellow tint-snob to consider to help with (but unfortunately not entirely eliminating) green tint-shift. It has the added benfit of less light loss than lens filters.
In any event, I’m putting this out there for consideration. Perhaps someone can make Magenta Collars available commercially.
Yeah, I realize the only thing they have in common is “side emissions” and “collar” but you can imagine how your title caught my eye.
This was something I debated about writing up/sharing because it seems so silly but you know us tint-snobs, we’ll go to great lenths and spend a lot of green just to avoid the green.
Yes, I was just thinking out aloud. But there are optical adhesives that may also work as well as better match the refractive index of glass.
As to paint versus ZozzV6’s “slice and dice” method… I think that when you do the “dice” cut, the sides have a TIR effect as well, redirecting light either to the top surface, or back into the emitter itself. Maybe even putting a reflective coating on those vertical surfaces would enhance the effect.
I also thought of doing a ZozzV6 “slice and dice” and building up the outer perimeter with some kind of cement/epoxy mixture to make a giant version of a White Flat. Maybe not so useful, but it would protect and insulate the bond wires.
Yes, if you’re chasing the last percent, painted sides should work.
Actually it could allow you to avoid dicing at all. Just paint sides and you’ll eliminate side emissions. Maybe not the whole tint shift (because side phosphor may generate photons that go a bit upwards).
Collar tint (and CRI) issues aside, couldn't we also attain increased intensity/output by hitting the die off-angle with one or more blue lasers focused onto it? Without collar, of course. Plenty of available blue laser emitters with the same frequency as the emitter's blue die, there would be no tint shift and no CRI crapping (I hope).
I forgot to say that before:
A very nice idea! Would really like to see it implemented with XHP70.2.
I wonder if painting the lower part of reflector would work?
I don’t expect any of this will be very successful. I expect The larger the difference in collar and die size the greater the return of side emissions directly back onto the phospohors.
A spherical reflector tries to reflect photons back onto the phospohors for recycling. The smaller the reflector the greater the change in incident angle across the die. Same reason a big lense is better then a small one. The smaller the dome the more likely the light hits off angle and ends up either getting lost due to being absorbed in the dome material, heading out the opening at an odd angle, or not hitting the phosphors at all.
It should but I was reluctant to mess with reflector in any way (I know better), the emitter on the other hand will withstand more handling.
Plus when I first did this, I figured if it was a disaster, I could simply de-dome. With a reflector I’d have no way of removing the tint without handling which would leave marks.
I posted a questing about the same thing. I too am very interested to see if the leds themselves can be laser pumped.
That said, if it was only the blue light from the led being bounced back and reexciting the phospohors then we wouldn’t see a doubling of intensity with a RLT collar, there just isn’t as much blue phospohors in the already converted white light.
I’m starting to believe the best way to think of the led surface as a mirror. If you can return all the stray light you get a much higher chance of it reflecting in the right direction. A laser just tries to get more light from the led, that doesn’t happen. If you can return the lost light it can have a chance of going the right direction the next time, it may take hundreds of tries, but it will eventually. Laser pumping still loses the stray light and doesn’t make the led make “more” light. You may get “reflections” of your laser, so you added that power, but it too goes random directions.
I expect the phosphors are like inductors, they can become saturated and not release more light, but maybe they can “reflect” the light coming back on them.
Once concern I have is how reflective is the paint going to be that you put on the dome. What color paint would you use? White? Silver? Mirror spray paint?
If you use white, the paint will reflect light in all directions… not just back to the source. If you try silver mirror spray paint… that stuff produces a mirror surface on glass, but isn’t designed for spraying on silicone. Not sure what result you’ll get.
And in any event, I doubt these paints are designed for high heat. Is your paint going to cook and catch on fire? Someone should try it and find out.
