Which second charger to get?
I’m getting a second Li-Ion charger, as I need another one besides my Gyrfalcon All-44. Two features that I really want to get are:
- Capacity check (via charge-discharge cycles)
  • Internal Resistance Reading
Are there any good ones that support both of these functions? I’m getting the sense that the LittoKala Lil-300/Lil-500 has suspect IR measurements, and that’s the only one I know of that offers it.
As an aside, I’m also open to getting a separate IR meter if cost is reasonable. There are some ~$10-15 electronic boards I see on Aliexpress that claims to test it, just not sure if anyone had good experience with it. Usually packaged IR meters run $40 and that’s too much to spend. And I also realize I can do the measurements manually with a bit of math but I’m too lazy :slight_smile:
Thanks!
My first charger was an Opus 3100 v2.2.
My second one will be a smaller one I can power from a 12v cig lighter socket in a car, so I can charge cells while traveling. Still looking at choices on those.
slmjim
The Zanflare C4 fits both of your requirements (except perhaps being small) as mine came with a 12v car charger too.
HKJ latest review of the Nitecore UMS2 seems to fit the bill for something smaller. Just use whatever 2A car USB adapter you have.
https://lygte-info.dk/review/Review%20Charger%20Nitecore%20UMS2%20UK.html
