Got mine today also and all i can say is AWSOME i'm very pleased with the light, all i want now is one with a 8v driver so i can use it in my L2x extended :-)
Just stuck it on the lightbox to see how it fared after around an hour on high - it was quite hot but that was probably because it has been sitting on top of the vents of this machine's monitor. I got 2720 lux / 488 lumens. Will check cell voltage and current draw now 1716mA and 3.727V. So it is good for around an hour on high on a "2500mAh" unprotected Trustfire cell.
With the light still hot from previous cell I got 3750 lux out of it on a freshly charged "2500mAh" unprotected Trustfire cell. Will do lux readings at 5-minute intervals to see what happens.
These cells are a couple of years old and have quite a few cycles on them - you might well get better performance from newer or better cells. The foil trick in the L2m certainly works well - the whole light is hot.
Did I say how much i dislike the Solarforce forward clicky - IMO forward clickies have no place in multimode lights. And my one feels horrible anyway, mushy and generally nasty. The "tactical" reverse clicky it came with is a much better switch but is prone to unexpected operation. But since the old Wf-504B/Uniquefire L2 tailcap fits and works well, this isn't really a problem.
But Excel is driving me insane. As @^%&^**%&^ ever, Microsoft think they know better than I do what I want. The bottom values reading 1-7 should read 0,5,10,15,20,25,30 but Excel in its infinite arrogance has decided I can't have that as I'm clearly too stupid to know what I want. This is what I hate about every single piece of Microsoft's garbage is has been my bad luck to encounter. This point is close to trying to get XP Home remember wireless settings when it just knows you don't really want it to work so it changes the settings back to "broken". They always try too hard to be clever and fail miserably.
But plastic reflector... I'm still searching for a nice 2*18650 host. I'd prefer one that doesn't look like the average Trustfire (like http://www.dealextreme.com/details.dx/sku.30683).
I keep an eye on the Sacredfire. It does look a bit like TR-1200 but the pill sits (screws to?) in the body in Sacredfire so I expect better heat transfer.
14mm with T5 & T6 @ Cutter. Still waiting for my second Trustfire R5-A3 to come (hopefully with the new driver & its usable low mode), and just added a KD C8 XM-L T6 to the "waiting for HK" list. Plus a bunch of Romisen XR-E stocking stuffers and another Aurora SH-035 for my dad... And really... I just can't wait for the XM-L.
Just got my XML today. It's very nice! Brighter than my MC-E and without the cross. Mine only seems to pull 2.20amps on high with a Sony 4.20V battery.
Edit: Tried it with a Trustfire flame (real one) and it pulls 2.7amps :)
Fortunately i have a bunch of good cells. A few XTAR 18700 2400 protected - same thing as 18650 protected size wise and some Himax 2600 mAh (formerly known as WOW). Both are pretty decent. Only The XTAR cell have kicked the low voltage protection yet have to see if the himax works.
Waitng for my 4 distrustifre errr... for a refund.
