Thanks Firemedic, I’ll keep hunting!
$0.673 per emitter? When I see super low prices per emitter on DigiKey, you’ve got to buy a minimum in the hundreds… I guess that’s the same deal?
Concerning the mistake about the MCPCB, the E07 is a quite expensive model but it can be used in muggle mode which is fine. Worth the 6 clicks from OFF to test it :+1:
Thank you ToyKepper
NB : double clicks turn off the light, ceiling and floor are reasonably bright in their respective levels. Perfect for muggles, useful for flashlights aficionados.
Floor should be a tiiny bit lowwerrr.
I would not recommend the 30T for day to day use. I only use it for testing consistency to compare with other lights.
Generally I aim for about 5 lm as the muggle mode floor. Any lower than that, and people start asking “is this thing on?”. However, on my E07 it looks like the muggle floor is about 9 lumens. So yeah, it should probably be a bit lower.
Following in the footsteps of others, I’ve swapped emitters to LH351D 5000K W6. This is easily one of my favorites now and have to agree that moonlight looks delicious!
(This is a little blown out, but a good representation of the wall of light the LH315D | 30T combo produces)
Cool mod… where is the best place to get those LH351D 5000K W6?
I actually like the 70 CRI 5000K W6 better than the 80 CRI 5000K U6, just seems whiter to me and that’s what I like. AAAND, more powerful.
DigiKey has had them, not sure if they still do… pretty cheap as well. (they show some 720 in stock as of a few seconds ago)
Dale, you were the inspiration behind this swap, so thanks for showing me the light.
I got 35 of them from DigiKey recently.
I just got a gray one last month. The fins are squared off and you can catch your skin on them pretty easily. Meh whatever. I’d be more concerned with how the driver thermal steps down from turbo in under 10 seconds due to the lack of thermal paste that’s been discussed. Fins don’t do much good if it overheats at the mcpcb and driver that quickly don’tcha think. Now we’re talking major design and buld flaw on yet another Fireflies torch.
You bet jdh00, really rocks now in output too doesn’t it?
Getting em like that, in a quantity, brings the price down to below $2 each, can’t resist when I’m at their site and got 30 last time myself. Really liking these Samsung emitters, funny, that, as I was going to resist trying them at first. lol
I just a few minutes ago ordered a fairly pricey chunk of Tellurium Copper… in part to make a finned heat sink extension for my E07, seems to need it these days…
I’m having a lot of issues where I keep squeezing the o-ring out of the rear on mine, it gets pinch between tail cap and the body. Looking at the O-ring groove it doesn’t look like it’s machine very well it doesn’t look like a typical light would be cut. There’s also pretty bad galling in the groove.
I’ll get my real camera and take a pic later but in the mean time, Dale would you mind giving your professional opinion on yours?
Mine has a semi-slim clear o-ring that fits perfectly, no bind no pinch. I don’t remember if it came that way or if I changed it, to be honest, but since the head end also has a nicely fitted clear o-ring I’m going to have to assume this is the way it came. The groove does seem to be pretty minimal under the o-ring, hadn’t noticed it as I didn’t remove the o-ring before. Mine has the o-ring groove cut in a rounded profile that matches the o-ring, looks smooth and well cut though.
Does it look like this?
Dale & jdh00 - Your LH351D emitter swap looks a great idea. What is the output level of the LH351D vs the stock XPL-HI? I understand it that they are pretty close in output (unlike the SST-20 that seem way behind in lumens) - but don’t know what the result is in the real world. I like floody more than throwy so the swap is very tempting….
So…ordered mine from Nielsgadgets about 12 days ago, paid for the express shipping…
My Paypal account has been charged (indicating order processed by Neil’s website), but i haven’t even got a “shipped” notice yet.
Guess I’m not going to get it in “7-9 days”.
You hit the Chinese holiday bout perfect. Just got an Ali order shipped tonight - they are just getting back to work.
The Samsung LH351D in W6 power bin is more like the XP-L2 in output than it is the standard XP-L emitter. Without the undesirable qualities of the 2.
I am curious to learn how the driver would detect excess heat and step down in a situation where this same heat isn’t reaching the cooling fins…?
Hold the head, at the fins, and engage Turbo… how long til you can’t hold these “useless fins”?
