Thanks for all of the recommendations - the Lumintop from fastech looks like almost exactly what I have in mind. I’m gonna read over a couple reviews and probably pick one up.
The Rovyvon Aurora is a bit different, but now I’m tempted to get one of those too
If you like moonlight, high CRI and some extras on the side (UV light + RED light + White light), and if you don’t like Strobes, I’d recommend the RovyVon Aurora A8! :+1:
Unno, for a keychain light, bouncing around in a pocket with other crap that can press in random places, I’d prefer a twisty to try to prevent accidental activation. So for me, a Jet-II would be about perfect for a 16340 light.
Some of the Wuben E-series come in 16340s as well as 14500s, so czech ’em out, too.
Funny(?), but every time I see your handle, I read it as “Mr Steal Your Organs”. Visions of waking up in a bathtub filled with ice are rather disturbing, I gotta admit.
Are you referring to the RovyVon?
So far they have been “pocket activation proof”:
Press&Hold for momentary Turbo
Double click for moonlight (and clicks to advance modes)
Triple click & 4 clicks to activate the side LEDs
I’ve been using it for a while and it didn’t lit up a single time. I can’t say the same for my Nitefox K3 (twisty) and even the Olight i3T EOS (Forward clicky switch).
Unless if locked (electronically or physically), the Wubens will have more probability to turn ON in a pocket as they use single click to turn ON in the last used mode!
Tank 007 E18
I have a few of these. Three mode twisty. Turns on in the the same mode you turned it off in.(at least mine does) Unfortunately one mode is strobe but it has less weight that a stainless light and is pretty well made for the money.
Ahah, sorry, thought you were talking about the possibilities of having a side switch button turning on in the pocket
Ahh, those!! They seem nicely built and very reliable. I was tempted to get one a while ago in a groupbuy from _ the _but never went through. Would be a nice choice, though!
not sure if they are the same now, mine was 3-4 year ago, looks the same though, mine even has a great neutral white color light and a nice pattern
really!
How about a sliding or rotating cover to protect the power button?
Like the threaded ring that Zanflare uses to cover its USB port.
Make it so closing the cover turns the light off ……
The lock out method works just fine. The only twisty I ever really carried was the Jetbeam AA light. Jet something, I always get them mixed up. It came on more than a few times loose in my pocket and just a few times clipped on my pocket. Not that big of a deal really. I noticed it before it was able to drain the cell down too terribly. Then I started carrying mostly tail clicky lights and now I’m back to carrying mostly side switch lights. Nicely recessed switches so I have never had one of those come on. I have had a Tip and a Tini that come on way too easy in my pocket on a keychain. Love them both, but they are always dead.
I used the Nitefox K3 (twisty) for a while in the keychain and was quite good!
It was only replaced because the RovyVon Auroras are less big and are lighter than it, and also because of the side switch, that is preferable in some situations.
Thanks for everyone’s recommendations on twistys - I don’t normally prefer one, but I do understand that they generally allow for a smaller overall size, so I might consider that route.
