Received my black S2+ host and immediately proceeded to give it a bit of heat treatment before transplanting my Luxeon V triple into it. Makes the little hot rod look a bit more gnarly and hot rod-like!
D-C fix should have like 5-10% loss shouldnt it? Sphere never seems to react well when light is diffused at lens
That is worrying since the whole point of a sphere is integration.
I modded an old glass door knob & old pipe into a light .
I assume your setup is probably a bit more refined since you also do bare LEDs. Do you have a regulated light you can try with and without D-C Fix?
I do not own DC-fix. The method I use is frosting the glass with sand paper. But that would not measure the right thing I suppose.
RW, that’s amazing! Nice work! Love it when parts at hand are put to good use.
Thanks , it was a learning experience . Hopefully the next thing will be a little better , I mean my efforts .
Today I have modified Skilhunt H03. Another with the rest. Previously I changed the diode on XP-L HI, now I changed the driver. The choice fell on Emisar (D1). I like the results very much. I have a ramp and a lot of power.
EagleEye X6
4x Luxeon V
Ledil Angie optic
MTN-17DDm
LED4Power spacer + mcpcb
Parts (with the giant hole I drilled in X6 shelf)
Spacer bolt (hollow for wires)
Spacer top side (bolted down)
Originally had everything wired up for a LD-B4 driver but I had issues and abandoned it. Here I demonstrate the art of wire stretchers to keep your mcpcb off your thermal paste while you solder your connections
Abort, bypass this FET and lets go with what we have that works
Moon. Too bright w/ Luxeon V’s
I used two O rings cause i’m not sure the bezel applies enough pressure otherwise. I may try it with one and test heat transfer or try to find thicker glass.
That must have impressive output contactcr!
Nice mod komeko, did you request the D1 driver from Hank?
Yes, Hank turned out so nice that one of them sold me
This is a very interesting mod Komeko. Can you comment any more on how you did it? Was it an easy driver swap?
Well, the tube is glued, so I used heavy tools. The driver was a bit too big so I polished it a bit. The diode is XP-LHI 3A. MX4 paste. Of course, I set the thermal protection to over 70 degrees Celsius. The turbo withstands 90 seconds which I consider to be a great result, after which it gently goes down. The temperature after 6 minutes is 76 degrees, hot, but it does not bother me. I have the same set of Emisara D4.
Received and modded a new Raspberry Pi 3 B+ today.
Now running libreelec 9 and it couldn’t be any better. Only 31°C while streaming 720p with a copper heatsink and no case.
Love it.
Purchased and fulfilled via Amazon because I had to empty my Entropay cards (they are shutting down, if you have money on Entropay either withdraw it to your bank account or spend it!). Delivered in less than 24 hours without Prime. wow!
I can not believe how much computing power you can get these days for a budget of 35 $US.
Received and modded a new Raspberry Pie 3 B+ today.
Love it.Purchased and fulfilled via Amazon because I had to empty my Entropay cards (they are shutting down, if you have money on Entropay either withdraw it to your bank account or spend it!). Delivered in less than 24 hours without Prime. wow!
Sweet… Got a couple not to long ago, with projects lined up for them…
One really cool project for BLF folks would be 18650/battery discharging automation with a RPI including plotting.
Or a more complex Luxmeter or other light measurement.
What projects are you planning @LouieAtienza ?
I run PiHole on another rpie 3 that also does Flightaware (Piaware).
Or a more complex Luxmeter or other light measurement.What projects are you planning @LouieAtienza ?
One project I have is for a touchscreen-controlled lightbar system; I have a 4-channel relay board and some MeanWell boost drivers that can do 0-10V dimming. So it would be cool for the user to save configurable presets for the center throw lights and outer floods, and even have each preset “morph” into an other. My other project was a small portable CNC engraver that I can take on-site for doing on-time award engraving… but not sure if I’m going to get to that one. Being I have a small benchtop router, mini-mill, and 3D printer I’m not sure I need another “mill,” though I have a small mini-lathe that might end up getting the CNC treatment.
I got a 0W just waiting for me… company finally changed from their windoze-only vpn to one that’s also available for linux, and with the 0W I can just stickytape it to the back of a monitor, power it from the monitor’s usb socket, and with a bluetoof keyboard have the entire setup, well, like that.
HDMI to the monitor, bluetoof to the keyboard/trackpad, usb for power, built-in wifi to get to the outside world. What else does it need?
Best part, I got the 0W for either 5bux or 10bux at Microstore. Forgot which. Mightta been the 0 for 5bux, 0W for 10bux. Either way, it’s a steal.
I envy y’all’s knowledge that allows you to “play” with these things. I was seeing the Pi Rasberry as a gift for ordering other things and had no clue what to do with it… oddly enough I got out of high school and started college in computer programming back in the day. lol (Cobol, keypunch, like that… 1980)
