I suggest you leave the ramping part of the dial smooth, like the original RRT-01, which only has detents for Off and Maximum.
I suggest no detents after on, except Yes a detente at Off, but no other detentes, not even for Masimum
and get rid of the 9 hash marks in the ramping track of the new RRT-01… just give us a totally smooth track after the light turns ON.
That is why I like the original RRT-01, the ramping is on a smooth track, and that is why I do not like the Eye10, there are 9 detentes in the ramping track.
I also suggest you offer a version with High CRI, but please do not use an XP-G3 for that… Nichia 219b would be my first pick… especially the 4500k 9080 version (I can dream )
hello, Jon. thanks for your advice. Have forward it to the engineer about the detents. The detents may make the light more sense of aesthetics? 1-2 detents may indicate the mode setting. What others say?
As for the High CRI, we will check the various items and cost.
My Eye10 has the same feature.
it turns out that it works without actually hitting maximum, also with down up, down up
iow, it is the quick double, down then up, ramping (from ON), that triggers strobe, not the fact that it hits maximum.
but yes, hitting maximum twice also does turn on strobe
regardless of hitting maximum or not, to turn on strobe, no detente is needed on Maximum, and the strobe, once triggered can be dimmed, and strobe will continue, even when not on maximum
