Think we can engineer it to not need a battery?
Electrolyte solution cathode in the battery tube, some sort of resin coating on the inner tube for the separation layer then the tantalum body is the anode.
May I propose the FW3O – The Osmium Edition.
Osmium is the densest element, is ridiculously hard, super high melting point, very rare (though not as expensive as gold). It also has a beautiful blueish/cold silver color. Heat transfer similar to iron, so better than titanium. Basically impossible to machine… So perfectly unreasonable for a flashlight
Well while we are naming exotic hard to machine metals…
FW3ST - Stellite
FW3CA - Carbide
FW3TU - Tungsten
FW3CR - Chromium
FW3CE - Ceramic
FW3CO - Cobalt
All are quite fun to machine. I do get to machine some pretty exotic materials and its always a fun learning experience.
And for the more sci-fi folks we have the
FW3DM - Dark Matter
You have to keep it in a vacuum suspension chamber next to your Uranium and Plutonium models underneath your volcano evil lair.
Yeah we use it for reactor plant valve seals and some turbine parts. I got to do some work with sintered parts as well a while back and we made some stuff from sintered Tungsten and ceramic with Molybenemum. Surface finish requirements were sub 20 RA using a Mitsubishi wire EDM and a tolerance of -+ 0.0001. What a flashlight that would make huh?
