【convoy】H4 and B35AM options are updated
My ramping driver is in production now ,It is controlled by a mechanical switch. I will describe the UI in detail later.
If Toykeeper has suitable solution, I will also produce the corresponding driver for BLFers
and I might design another 21700 host to fit carclo optics
Personal preference - S11 in 26650, LH351D 5000k, OP, Narsil firmware. But that’s just me :slight_smile:
Ordered placed. Thanks for all the feedback and effort.
Ordered. Many thanks.
Simon could you include 22 to 17 mm. driver adapter in the package?
I thought you said the S2+ 21700 will fit carclo quad optics? Oh well, I guess at least I can swap in my triple pills from my 18650 S2+ into the 21700 S2+ for longer runtime and better heat dissipation.
I’m very impressed with my S2+ SST-20, are the specs on the SST-40 you would use in the S11 the same?
I would recommend trying to get the 5000K SST40 Simon
Currently no adapter,sorry
+1
I was wondering the same thing. A 17mm Led4power driver + Luxeon Mz might be good match for this host. Give me a chance to use the MosDTP 4040 board (copper not aluminum)
Looking at the Ali Express pill picture of the S11, maybe the driver retaining ring could be flipped around. And it would create a smaller shelf you could solder the driver to. You would need to carefully cut slots on the inner diameter of the ring so you could tighten it down. What are the dimensions of the retaining ring? Looks larger than a 17mm opening but there are a few 17mm To 20mm Brass Adapter Rings on Ebay.
Thanks for any help.
Can´t wait to get the light :slight_smile:
Insta-buy! 26650 version as well!
Cheers and thanks!
no problem ,i will get some 5000K
i will consider to produce some adapters if many guys need it
Excellent!! :+1:
Hi Simon.
Could I order a Convoy S11 with an XHP70.2 ~5000K NW, no blinky modes and 0.1% > 1% > 10% > 100% levels and toggle memory by config ?
Also, are there any other different colors available to pick from for this host, like desert tan for ex. ? And if so, how much would all of this cost ?
Regards.
Simon, could you please tell us what SST-20 tints you’ve got in stock at the moment?
sorry ,XHP70.2 can not be installed
another model with XHP70.2 run on single 26650 will be available soon.
currently ,there is only black
