My BLF A6 has worked for 15 days
it’s never fall
I always take care of it
and now it’s a piece of metal good for trash :rage:
I guess by posting it here on BLF you are asking for help getting it to work again? We do know a thing or 2 about that light, what happened?
Ouais, qu’est-ce qui est arrivé à la BLF A6?
Yeah, what happened with the BLF A6
merci de vos réponse
ce qui est arrivé est bien simple je l’allumais je l’ai eteints et quand j’ai voulu la rallumer
plus rien
la pile fonctionne avec d’autres flash light
thank you for your answer
what happened is very simple I turned it off and when I wanted to turn it on again
nothing
the battery works with other flashligh
Sorry to hear your BLF A6 has stopped working.
There is a BLF A6 FET+7135 Light Troubleshooting and Mod thread that may be of some help. It's a long thread but contains some great information.
thanks
Triage - Have you checked if the retaining rings were tightened?
Take the light apart in: the head combo - the tube - the tail.
There are retaining rings in the head combo and in the tail.
These are to be fastened (quite firm) in the clock-wise direction.
No tools? Check this METHOD Works as least as good as buying a special pair of pliers.
Retaining rings are tightened? Next quick check.
Screw the tube back into the head combo and put it on the table, head combo down.
Put a battery in the tube, with the plus side down, in the direction of the head combo.
Take some electrical wire and make contact between the backside of the battery and a bare part of the tube.
If it does not light up, it is probably a driver issue, you should ask smarter persons to help you
If it does light up, screw the tail back on and look if this time you can switch the light on and off.
If you can, problem is solved. If not, try one more time to fasten the retaining ring in the tail cap.
If after that, you still can’t switch the light on and off, the switch itself might be kaputt.
thanks Henk4U2
I reversed the head and the tail
it WORKS !!!
I was so sad
This flashlight is so beautiful
thanks Henk4U2 for your time
That’s BLF at work for you. Great tips, Henk4U2! And glad to see you’re up and running again with your BLF A6, nonorobo.
Btw, what’s a NoNo Robo?
nonorobo is a little man (me) who's name is Bruno nono the little robot nonorobo :D
