Awesome! Congrats! Lucky bli#sem…
Thanks :money_mouth_face:
Hmmm…… I have tried to order the “NEW Convoy S2+ SST20” twice now, several hours apart. Each time it says: “The daily limit for this coupon has been reached. Please try again tomorrow.”
Is anyone else experiencing this??
worked fine here just now……
Thanks saypat… it worked fine for me this try also. :+1:
How many 7135 chips did you get on yours? I got 7135 x 8.
I didn’t order one teacher, just checked to see if it worked for you I would have ordered the 7135 x 8 if it was available immediately, don’t like waiting for the preorder, then waiting again for the shipping. Love the tint on this light!
Ok thanks saypat, I understand. I know what you mean about the waiting. I just went ahead & did it anyway so I wouldn’t miss the deal price or forget to order completely.
I am looking forward to getting this. It will be my first SST20 so I’m looking forward to seeing what it is like.
Any idea for the estimated lumens of the Convoy S2+ SST20-4000K for each of the 4 variations (7135x3, x4, x6, x8; ie. 1.05A, 1.4A, 2.1A, 2.8Amps)?
If we take the example of 2.8A = 650 lumen then we can extrapolate the lower units based off the typical output curve. So probably something like this:
3x - 280lm
4x - 360lm
6x - 510lm
8x - 650lm
Good question d_t_a. . Thanks for the answer Jason. . . :+1:
Hello my dear friends!
here are some new items i found on banggood:
18650 to 21700 Battery Adapter
For Astrolux FT01 / FT02 / FT03
just USD 1.99 (Promo)
for the Fitorch P25 "Fatty" (get it here for $32.99)
Fitorch UC20 26350 Battery
2000mAh Lithium-ion USB Rechargeable For P25
(i hope code is available soon)
1Pcs Fitorch P25 Extended Tube
DIY From 26350 To 26650 Battery Tube
just $2.50 (Promo)
I wonder it that 18650 to 21700 Battery Adapter would work on other 21700 lights as well??
i am very sure it will ;)
/\ …. Thank you MM.
It is basically adding 5mm in length and 3mm in diameter to make an 18650 fit where a 21700 would go.
Thanks Jason, that’s what I figured; but…. I also was wondering/thinking the base might possibly be proprietary to the Astrolux models listed.
Either way, I ordered a couple. :+1:
d_t_a:Any idea for the estimated lumens of the Convoy S2+ SST20-4000K for each of the 4 variations (7135x3, x4, x6, x8; ie. 1.05A, 1.4A, 2.1A, 2.8Amps)?
3x - 280lm
4x - 360lm
6x - 510lm
8x - 650lm
This values seem a bit on the high side, since Simon is using SST-20-W40H-A120-J4402 , i.e. J4 Flux Bin (3A @85ºC 556lm)
JasonWW: d_t_a:Any idea for the estimated lumens of the Convoy S2+ SST20-4000K for each of the 4 variations (7135x3, x4, x6, x8; ie. 1.05A, 1.4A, 2.1A, 2.8Amps)?
3x - 280lm
4x - 360lm
6x - 510lm
8x - 650lmThis values seem a bit on the high side, since Simon is using SST-20-W40H-A120-J4402 , i.e. J4 Flux Bin (3A @85ºC 556lm)
It’s all relative. If 2.8A = 520 (20% less than 650) then adjust everything down 20%.
3x - 225lm
4x - 290lm
6x - 410lm
8x - 520lm
Does the FT03 group buy include the 18650 -> 21700 adapter? It’s supposed to be 26650 compatible too so how can a 21mm cell adapter work?
Yeah I’m kind of worried too…
I mean, I planned to use a 26650 in it
