Yeah…
I’ve had a very similar build in my head. Just with high-CRI XP-L HI. Didn’t think about Crescendo but it would likely be a good choice for me.
But it’s really a bit large to carry on my neck. I wear Foursevens Mini Turbo sometimes and it’s too large already but I love the punch that it offers. i3 has the same diameter but is somewhat longer…So I’m not really into getting one but it stays there at the back of my head. And if I had one it would surely have its use.
Hum, a High-CRI in this would be nice, specially when zoomed out :heart_eyes:
I opted for the CW, as I was trying to get more light out of it. I should have used a Neutral White, specially for indoor use. But…I still have in mind to change it and eventually use a Luxeon V or V2 on it
Yup, to neck carrying it is quite bulky, the head is large in this light! Larger than the 4Sevens, I’m sure! It can be a light to carry in the pocket or jacket, maybe, and that’s the way I’m using it after this mod.
As for neck light, I’m carrying the RovyVon Aurora A8
BTW, if you even decide to buy it and change the driver, please be aware that 15mm drivers fit, but only without springs or 7135 chips in the back. There is small space for the switch spring and the battery itself!
Thanks for the note.
BTW 47 Mini Turbo has one inch diameter. So actually slightly larger than this.
Too large to be usable on a short string but if it goes down to my belly - it’s actually OK. Surely not something I would call practical though.
Ooops, I confused the flashlight, thought it was the thinner
Ahah, only issue I see with these big neck lights is we have them in the chest some friend slaps you there and we scream an “Ouch!!!”
Thanks
Yup, the Neutral White (XML2) was quite nice, I just opted for the CW due to light output! I still may change it at least for a warmer led
I actually didn’t like much the UI, specially the fact that with some faster clicks to advance modes it would turn on Strobe :zipper_mouth_face: That’s annoying!
But your “hypothetical” configuration for this light seems good
I may still check which LEDs with High Cri work well with this MTN driver :nerd_face:
This light is something I would need but in 18650 format…
Don’t be mad guys but there is no point of modding this light with FET driver… This light uses 16340 batteries (cause frankly speaking we don’t have any quality 16340 batteries out there, and even if there is few good models they can’t compare in quality with brand 18650 batteries).
Is there any light like this On The Road i3 but with 18650 battery format?
Mini flashlight with 18650 format with 25mm body (not that stupid fat 3xAAA format), glass lenses, anodized threads? Guys finding good budget host with such specifications is almost mission impossible and this On The Road i3 is closest to that but it is constructed for freaking 16340 cell
I haven’t find any… OTR manufacturer if you’ll read this make 18650 version of this small superbly designed zoomie…
Well, I didn’t find it in the 18650 format, despite OTR once sold zoomies in that format too, but I guess they were larger! Their website is down, otherwise you’d be able to check those older models
I modded it to have a better UI, not because it was a FET. However, with the new Vapcell cells (800mAh, 7A) a FET driver will have some “utility”, and I have 2 on the way :smiling_imp:
Well, the best I can tell you is that soon I will be using a 16650 2500mAh battery on it :smiling_imp:
How? By removing the tailswitch of the i3 and using the battery tube of the OTR M1 on it, as the thread match! So…it will be thinner than a 18650 flashlight But…you need to have both flashlights to make this “mash-up”
Are you still in contact with OTR manufacturer? You could open group buy for new ODM OTR light with single 18650 tube and maybe 17mm driver pill version…
I would like everything same as on this “On The Road i3” but tube designed for 18650 cell and pill that accepts 17mm drivers if possible.
I may contact him and see if they have any plans for that kind of flashlight! Still would need to be lager than this anyway, to fit the 18650 battery.
The inner and outer diameter will always grow a bit to make it fit!
I do like this option you mention, though as it would be slim and not as bulky as some zoomable lights we see nowadays. BUT, for that, the driver still needs to be 15mm, as a 17mm driver will make the pill grow in diameter. So…it would be hard to meet all the requirements.
I will contact the manufacturer and try to get any info on that
I think it is still available
And I think they will not be able to do something less thicker than this. I just sent message to the OTR contact and will be looking for his reply
The numbers don’t make sense for the second linked light - the ChengInn - only 4 hours run time with a max output of 260 lumens with an 18650 as the power source?
Hum, I was not looking to those aspects actually, just to the host itself! Not sure how good it would be (specially the pill, probably aluminium, and the lens, probably acrylic, not glass) but I also like the form factor.
About runtimes, we always know how these lights’ specs are presented, right? :person_facepalming:
What light are you mentioning? The OTR i3 or the other OTR from Fasttech I linked?
It it is the i3, it has a pocket clip. If you decide to purchase it on AliExpress, send the seller a message.
If the other OTR, I don’t think it has a clip at all
Same question, is it about the OTR i3?
If so, the options for it are XML2 U3-1A / XML2 U3-5C / XP-G2 R5-1A being the U3-5C warmer than the U3-1A (cold white). My option was the U3-3C and it was more Neutral.
Nop, this one doesn’t seem to have one. Maybe a Convoy clip can be attached to it (not the screw-in clips, though).
I was referring to the I3 for the clip and emitter options.
I don’t see any optional accessories listed for the I3 on the aliexpress website, so I guess I would have to message the seller to find what the options are.
I would also have to buy a battery, so I’d also message the seller for battery suggestions.
I would likely chose the warm white option, if I buy one. I’m tired of cool white zoomies.
Thanks for all of your information and suggestions.
Ahh, ok ok
Well, I guess that if you send a message to the seller, even if it costs you some more bucks, he will include the cell and the clip. You can mention that you are from BLF and that you’ve seen this review as well
The OTR 16340s are good cells. If you don’t change the driver for a FET or “more powerful” one, that cell or a Sofirn 900mAh cell will be enough. Still, you have the recently launched Vapcell 16340 800mAh 7A cells that will give you probably the best option for the light. This will also be the best option in case you use a FET or “more powerful” driver
About the tint, if you chose the 5C I guess you won’t be disappointed. Next steps I will do in mine is to put a Luxeon V 4000K to make it warmer. And the other step is to replace the burnt driver :person_facepalming: (don’t ask, don’t tell!!)
In any case, ask the seller for that before making the order
Hope this helps!!
Nice find mate! BTW the one that is aliexpress linked does it has glass lenses on? They did not stated which lens do they use and since head has “short walk” they are probably acrylic lenses. But one problem it has 44$ of shipping cost!!! I mean WTF :person_facepalming: Probably some mistake from seller?
Anyway that Ali light would be ultra find if it has glass lens because it is budget 10$ light :+1:
BTW that 18650 OTR Fasttech ligth you linked has a bit dear price…, and I am not sure what to think on that glass lens retaining ring…
Can you talk them into price cool down?
