【convoy】219B R9080 TEST
5899 posts / 0 new
oweban
oweban's picture
Last seen: 6 months 1 week ago
Personal preference – S11 in 26650, LH351D 5000k, OP, Narsil firmware. But that’s just me Smile
Inkidu
Last seen: 1 year 9 months ago
Ordered placed. Thanks for all the feedback and effort.
1stein
1stein's picture
Last seen: 6 hours 17 min ago
Ordered. Many thanks.
Satan@103TFS
Last seen: 4 days 15 hours ago
Simon could you include 22 to 17 mm. driver adapter in the package?
SKV89
Last seen: 1 day 8 hours ago
Simon Mao wrote:
Ryzbor wrote:
So the quad Carclo optics will not fit in the 21700 S2+?
C8+ powered by a 35-40A 21700 modded with a FET and led4power spacer + 6x MCPCB gives some possibilities Evil
Simon, have you contacted Toykeeper about a ramping UI for that S11? I’m sure she can help you Wink
and I might design another 21700 host to fit carclo optics
I thought you said the S2+ 21700 will fit carclo quad optics? Oh well, I guess at least I can swap in my triple pills from my 18650 S2+ into the 21700 S2+ for longer runtime and better heat dissipation.
CMU_84
Simon Mao wrote:
Convoylover wrote:
Simon, Great that the 21700 light is coming!
I have put a 21700 in the Convoy BD01 and that fits fine lengthwise, so I expect that this will be fitting in the S11 too.
I hope that you also will have Biscotti drivers for XML2, XPL LEDs for the S11 / S2+ 21700, similar to the 18650 S2. I don’t always want XHP LEDs.
And OP and SMO reflectors similar to the M1/M2 lights Smile
i will launch another version – S11 with SST40 and ramping driver
I’m very impressed with my S2+ SST-20, are the specs on the SST-40 you would use in the S11 the same?
contactcr
Last seen: 12 hours 32 min ago
I would recommend trying to get the 5000K SST40 Simon
Simon Mao
Simon Mao's picture
Last seen: 2 days 11 hours ago
Currently no adapter,sorry
timbo114
timbo114's picture
Last seen: 7 hours 22 min ago
+1
Inkidu
I was wondering the same thing. A 17mm Led4power driver + Luxeon Mz might be good match for this host. Give me a chance to use the MosDTP 4040 board (copper not aluminum)
Looking at the Ali Express pill picture of the S11, maybe the driver retaining ring could be flipped around. And it would create a smaller shelf you could solder the driver to. You would need to carefully cut slots on the inner diameter of the ring so you could tighten it down. What are the dimensions of the retaining ring? Looks larger than a 17mm opening but there are a few 17mm To 20mm Brass Adapter Rings on Ebay.
Thanks for any help.
Krauttorch
Last seen: 7 months 3 days ago
Can´t wait to get the light Smile
80T
80T's picture
Last seen: 6 days 5 hours ago
Insta-buy! 26650 version as well!
Cheers and thanks!
Simon Mao
Simon Mao's picture
no problem ,i will get some 5000K
Simon Mao
Simon Mao's picture
i will consider to produce some adapters if many guys need it
teacher
teacher's picture
Last seen: 2 years 1 month ago
Excellent!! Thumbs Up
80T
80T's picture
Hi Simon.
Could I order a Convoy S11 with an XHP70.2 ~5000K NW, no blinky modes and 0.1% > 1% > 10% > 100% levels and toggle memory by config ?
Also, are there any other different colors available to pick from for this host, like desert tan for ex. ? And if so, how much would all of this cost ?
Regards.
P33
Simon, could you please tell us what SST-20 tints you’ve got in stock at the moment?
Simon Mao
Simon Mao's picture
80T wrote:
Hi Simon.
Regards.
sorry ,XHP70.2 can not be installed
another model with XHP70.2 run on single 26650 will be available soon.
currently ,there is only black
Simon Mao
Simon Mao's picture
6500K and 5000K (Ra=70)
4000k (ra=95)
80T
80T's picture
Same design as the S11, just 7x7 emitter compatible ?
Simon Mao
Simon Mao's picture
80T wrote:
Same design as the S11, just 7×7 emitter compatible ?
i understand ,but it needs suitable reflector
the bottom hole of the S11 reflector is 7mm ,it’s small
80T
80T's picture
Oh no, I was asking if the new design with the XHP70 will be basically the same design as the S11 / host Smile
Simon Mao
Simon Mao's picture
similar to BD06 ,but little bigger
80T
80T's picture
Ok then, I suppose it's going to be an S11 for me with the XHP50.2 for the moment Smile
Do you happen to have a beamshot of the S11 by the way ?
Regards
Simon Mao
Simon Mao's picture
80T wrote:
Ok then, I suppose it’s going to be an S11 for me with the CHP50.2 for the moment Smile
Regards
Light spot is very wide, It’s daytime here, Not convenient to take a photo,
80T
80T's picture
Perfect then, thanks a lot. I'll take one S11 with 5000k XHP50.2 if still available Smile And about the driver, do you have a 0.1 > 1 > 10 > 100 % version ?
moridin
Hey Simon,
are you going to sell the sst20 LEDs separately?
Simon Mao
Simon Mao's picture
80T wrote:
Perfect then, thanks a lot. I’ll take one S11 with 5000k XHP50.2 if still available Smile And about the driver, do you have a 0.1 > 1 > 10 > 100 % version ?
sorry ,mine is 0.1%-3%-30%-100%
Simon Mao
Simon Mao's picture
moridin wrote:
Hey Simon, are you going to sell the sst20 LEDs separately?
ok ,i will add links later
80T
80T's picture
I guess it's fine like so as well, it has the 0.1 and that's what I was the most interested in.
So how would I order one S11 ?
Thanks.
