Copper S2+ limited edition
Doesn’t really matter. Each person has their own preferences, and the one(s) you like are, by definition, the best.
I try not to encourage people to argue about whose favorite is best. It’s a bit like arguing over taste in music. Just enjoy what you like… even if it’s Nickelback.
I completely agree with you. I’m just curious and this is a discussion forum after all :slight_smile: .
Yes I also have a souped up SK98, no need to hide it ToyKeeper. Sexy zoomies to power!
To Simon, and all people, who requested 2700K Nichia 219C:
instead of that, I think, Luminus SST-20 of 2700K could be also considered. That emitter has superior deep reds in the spectrum compared to the Nichia 219C (R9 above 85 vs around 60).
Also, I think, people would love to see SST-20 3500K, as nearly nobody sells that, but it is a very sweet CCT.
I have four of the 2700K sst-20 in a custom built Convoy M2 Quad. It’s an awesome light. Lovely color, and very good color consistency, better then my R9050 2700K 219C. Expect a color warmer then the 219C as that emitter tends to hit 2850K while the sst-20 delivers a more of a 2700K, solidly hitting the mark. Color temperature across the beam is better and more uniform then the 219C.
I’m also working on a 3000K sst-20 light, and it also delivers a solid color temperature of 3000K. I really like the sst-20 range so far, it isn’t like Cree or Nichia that tend to be off with their warm white CCT. I hate the newer flip-chip Cree’s. Thier XP-E2 2700K fails to hit the mark metering around 3000K in frosted TIR optics. Without the TIR, it’s a Cree rainbow with the hotspot hitting 3100K+ and the yellowish rings hitting the 2900K range. Their 3000K models tend to show similar upwards bias.
I don’t know as much about the XP-G2 series, but I would probably avoid the XP-G3 in the warmer tint bins. I tested what was sold as some ANSI White 8B/2800K emitter that was very much over 3000K. It looked like they tried to play some sort of visual trickery to make the CCT appear warmer then what it was but failed. It had this unnatural rose/reddish tint, and poor color consistency across the beam. It did not play well the the orange peel reflector.
ok ,i will try to order SST20 3500K and 2700K,
SST20 1000PCS in a reel but 219C 3000PCS in a reel,
219C costs me too much :smiley:
I’d like to get another chance at the S2+ Copper. I only bought my first S2+ from FT in Jan. They haven’t arrived yet (hit customs this morning) :frowning: I saw the copper ones, but I had also gone a little haywire with spending on a new Leatherman Charge+, 2) BLF A6s, another budget flipper knife (Eafengrow EF66), Ti toothpicks and a bunch of other random things.
So, yeah, reading and following others’ suggestions for updates… Smooth body w/18350, triple Nichia 219, stainless switch cover and A6 driver. Too much to ask from a newbie? :popcorn:
I hear ya cetary. Only XP-G3 I've seen is a high CRI 5700K one which I bought from AEDe long ago. Not bad, but green (still one of them inside my led emitter cache).
I second the SST-20 high CRI proposal, tiny throwy turbo emitter. I mean, :-D cool.
Cheers :-)
You could build yourself one just like that, minus the copper part, all the parts are readily available and fairly cheap. Grab a host on Convoy’s AliExpress page. All the cool new colors are there, or you can take some oven cleaner to the light and strip off all the anodizing and have a raw aluminum custom light you built yourself. Super easy. If you get stuck on anything somebody is always here to help you out.
Thank you very much :partying_face:
Great, i wasnt aware the sst20 comes in 2700k, for me it wouldnt matter much really who makes the emitters as long as its very warm :smiley:
Simon so lets go buy it some sst20 emitters then ok…
i have got 1000pcs SST20 2700K ,i will add it in my store after several days later
Simon have you decided what the next batch will look like?
Simon please let us know when you get the 3500k sst20. Thanks!
i will send photos several days later
SST20 3500K not in stock
i only got 2700k
Simon will it be possible request to have tailswitch lighted ?
Resounding yes is my guess.
Built a torch with one of his blue lighted switches in the past. Used 5.1KΩ + 10KΩ bleeding resistors (≈3.37KΩ), it ended up being @#$% bright. I'd probably choose 10KΩ next time.
I understand the flashlight is going to be smooth.
What about optional body tubes with knurling? Perhaps also for an 18350 battery?
old version and 18350 tube will be produced ,too
